It's been hard going for the last couple of days, my pa died about 10 days ago and it only really hit me the end of last week, I think it was selecting poems for the service with the kids and writing a few words for his eulogy that set me off.
However I have tried to keep busy tidying the workshop and fiddling with the big Meddings radial arm saw I bought a while ago and doing a bit of fencing to keep the neighbour's cows off our willow saplings.
I started to mark up the legs a couple of days ago, but didn't get far. Fortunately it made me read the Benchcrafted criss-cross notes again, and I realised that the front stretcher needed to be altered to allow the barrel nut to go behind the recess for the criss-cross. It needed thickening up to 3" from 1-7/8". So I laminated that yesterday and put it through the PT today.
That bit of PT work galvanised me into action and I put the chop through the PT as I had forgotten to do that, then I started to cut out the recess for the criss-cross in both the front left leg and the vice chop.
First the leg, I don't have a spiral bit but I do have a long trimming router bit with a plunge tip. The slot is 1-7/16" deep, 3/4" wide and 19-1/2" long. I plunged to the full depth in a few passes then move the router bit towards the farthest pencil mark then turned the work around and did it again, I used stops at each end and used the router fence fine adjustment to take off about 1.5mm at a time.
I think this is close enough to 1-3/4"
Getting the end stops right meant very little tidy up, just the corners, I had a play with a few chisels just for the **** of it. I bought a corner chisel years ago, also tried my new Narex mortise chisel and I used a bevel edge chisel on a small patch in the middle of the recess that needed a bit of TLC. The Narex is lovely, not sure I need a corner chisel, it works ok I guess.
I have completed about 80% of the opposite recess on the chop when dinner and kids stopped play, I have a day tomorrow to repair any wind damage and hopefully make a start on the mortises on the legs for the stretchers then off to North Yorkshire for my dad's funeral Wednesday and Thursday.
Andy
