Andyandys wood shed":3tqfq2fx said:What cutter is used to make tenons?
It's to produce a counter or scribed profile as you might see in a frame and panel door (take a look at a cope and stick router cutter set and it may make more sense). In fact that block would be mounted to undercut the work (which would be the rails - top, bottom and middle), i.e. the block would sit low in the table and the work be passed over it.andys wood shed":28x1n6mq said:In the picture you kindly poster of the two cutters, the upper one appears to have a stepped profile. whats this for?
The profile on the rails would be cut using a conventional cutter block on the spindle moulder. The other (square) shoulder would be cut using a square cutter in a tenon discandys wood shed":28x1n6mq said:Also if you don't mind how would you produce the two remaining shoulders
I believe that Felderman has much more recent experience of this than I have (I use a single-end tenoner and a 7.5HP industrial spindle), although my past experience (on a Lurem combination woodworker) inclines me to say yes. My problem with that machine was that there was no stub/flush tenon available and the rings in the table only accommodated a 160mm cutter which in turn limited me to a 50mm tenon cheek length. You need to check this on your machine as it is the significant limiting factor. If possible I'd recommend clamping the work down onto a tenoning plate as this will be a generally safer approach and I'd also suggest that the carraige needs a backer board of hardwood or plywood mounted on it's face to reduce break-out. Be aware that if you are producing tenons inthis way your thicknessing needs to be spot on and even then minor adjustments might be necessary, especially if the timber is thicknessed one day and tenonen the next. On smaller machines (under 4HP) go for aluminium blocks as the machine will struggle to spin up and to brake a steel blockandys wood shed":28x1n6mq said:I have a project coming up and I will need to produce quite a number of tenons would you recommend this method as I have a spindle moulder with sliding carriage although I would have to buy the tenoning hood
