I'm building a small speaker cabinet for a bass amplifier, and it's made of 12mm softwood ply. I'm going to finish it with Duratex paint, which is a water - based paint for speaker cabinets. Some cracks needs to be filled in and I'm concern this might impair paint adhesion. In the website I found the advice
"MDF and plywood will readily accept DuraTex. Some resin, epoxy, plastic and solvent-based wood fillers will impair adhesion over the filled area. Hint: If you do use plastic/solvented fillers, a thin coat of PVA glue can be brushed over the affected zone, this will help seal any solvents, and prime the surface, significantly improving adhesion in these problem areas"
Can I use the regular Ronseal wood filler (acrylic resin and water)? Even better, can I use wood glue in places as a filler and sand it? I'm just a little confused around plastic, epoxy, solvent, acrylic :?
I heard that a mixture of half water and half wood glue can be used to seal wood before the finish, is it correct?
Thanks!
Thanks!
