Myfordman
In Remembrance 25/12/24 -- AKA 9Fingers
dickm":wvlvlcwy said:As a matter of interest, who is buyng the OP's generation? I sell to SSE (or "the Hydro" as we all call it) and also get my supply from them. Pretty sure that somewhere in the conditions for purchasing my generation, there is something that says inverter must switch off/be switched off in event of failure of mains supply. For all the reasons given above.
Grid tie inverters in UK must comply with G83 which amongst lots of other things, shuts down the inverter if the grid supply is out of spec in terms of voltage frequency and (i think,) impedance.
Most generators are not likely to be able to pass any of these tests.
The further problem is that a generator cannot absorb any excess power coming from an inverter when the house load is less than that being produced by the PV panels.
Most inverter manufacturers produce systems that will stand alone but not all of those will reconfigure a GTI into a stand alone one.
