nev":2vadetc4 said:Blades break, even Tuffsaws :shock: but he'll re-weld or replace it if it breaks at the weld.
Coincidentally I had two arrive yesterday and out of curiosity just went out to see how tight a turn I could manage with one of them .
This was a (73") 6mm (1/4") 10tpi Supertuff carbon, setup as per the Alex Snodgrass link someone posted a day or two ago on my small Woodster2 saw, with guides made from assorted bits of wood and plastic chopping board and partially seized thrust bearings, very far from a quality tool.![]()
Admittedly this is an unknown pallet wood, probably a pine of some sort but I had no issues whatsoever cutting pretty quickly through this 3 inch block.
As you can see a 20mm diameter semi circle was simple enough as was the larger 'box' cutout with a few tighter radii and with a very good finish to boot.
So possibly there may be some improvement you could make to the setup on your saw??
I shan't try and second guess Mr. Maskery's tuition tips as I'm sure he's forgotten more than I'll ever know about bandsaws.
Nev,
Can I ask what kerf this blade leaves if you just cut straight into wood.
I have exactly the same blade and I can only cut curves down to about 50mm diameter. I am getting a 0.9 to 1.0mm kerf in the wood as I cut.
I'm wondering if I have accidentally knocked the set off my blade while fiddling with the rubbish disc guides I have.
Neil
