Wow, lots to think of there, thanks.
Benchwayze":1s3pmup4 said:
Skirting doesn't have to be made in one piece. You could fix it so there's a small void behind it, (similar to wainscoting) even using MDF if you wished. It's fixed to the wall by a top batten, with a supporting batten behind it, along the floor and some verticals for stability. A separate moulding is planted on the top,.
Now here is a thought: if I fix a batten to the wall level with the top of the skirting with screws, can I then attach the skirting with lost head nails? How thick would the pieces need to be for this to work, I wonder? We have chosen a simple profile as this house was originally a quality-but-budget victorian abode, and the remaining original woodwork has a simple chamfer decoration. 45 degrees on the window frames, maybe 30 degrees on the other skirtings. Fortunately I can manage to cut this with a bearing-guided routers.
blackrodd":1s3pmup4 said:
Don't let the centre mitre cut worry you.
Take a decent handsaw with you and cut them in the wood yard. make sure the skirting is well supported.
Mark/cut the skirting @ 45 degrees and mark both sides to identify the pairs.
Should you be a little out on the cut, or even way out, it won't matter as you have the matching pair, so they have to fit.
Now that is practical. I will give that a try.
You may be aware that 1 rule of thumb fitting skirting, first piece fitted goes in opposite the door, blank each end.
I was thinking of starting there because that is the longest run. But I see the generalised logic matches this particular case.
Do not mitre internals corners, they are rarely 90 and there are shrinkage issues.
Easiest way to mark the SCRIBE to suit the 1st piece just fitted is to cut the skirting off the end at 45 degrees, as if it were for an internal, then the inside edge where the mitre ends is a perfect scribe of the profile.
I have a bit of trouble picturing this.... for a 90 degree corner I would have used a 90 degree cut as a template. Perhaps I am missing some essential point?
DrPhill":1s3pmup4 said:
You may mark and cut from an offcut should you find that easier. use a coping saw and a fine saw for the "straights"
Accurate measuring is king! 2, or 3, times! Bad language upsets the dog!
Luckily the profile will all be straights..... and even getting the tools out scares the younger dog.
Again thanks, I tend to assume that I will be able to do a job and often I can. But more often I find after that there were some tools, techniques or approaches that would have made the job easier and the result better. Folks on this forum really do help me miss out a few learning mistakes and let me benefit from their experience. It makes a big difference.
Phill
