Or how about these courtesy of Dave Richards
Working with small things--chess pieces in this example--the ability to scale up a copy to work on it while leaving the original in place. This would apply to drawing things like knobs and other small hardware.
http://www.finewoodworking.com/item/109 ... mall-parts
Modifying a model. Working efficiently in SketchUp.
http://www.finewoodworking.com/item/107 ... n-sketchup
I got the impression from his post and from others that he doesn't understand that things like left and right drawer or bookcase sides can be copies of the same component. I wonder if he draws the one side and then draws the other side separately.
More efficiency--don't draw the same thing repeatedly. Save the component for future use.
http://www.finewoodworking.com/item/107 ... able-screw
More efficiency--left and right and top and bottom counterparts:
http://www.finewoodworking.com/item/105 ... hup-part-i
More of the above:
http://www.finewoodworking.com/item/105 ... nd-drawers
More components for later use:
http://www.finewoodworking.com/item/580 ... our-models and
http://www.finewoodworking.com/item/574 ... -dovetails
Adjusting component axes:
http://www.finewoodworking.com/item/475 ... s-and-flip Can't do that with groups.
Exchanging one component for another.
http://www.finewoodworking.com/item/418 ... components Can't do that with groups, either.
Inserting components:
http://www.finewoodworking.com/item/416 ... -insertion
If you want an exploded view and an assembled view of a model, put them both in the same SKP file. If you need to make a change to the model, modify one and the other gets modified, too. Not with groups, though.
http://www.finewoodworking.com/item/408 ... oded-views
Applying materials to parts in the model. Open one component for editing and apply the materials to the faces (where they should be applied) and all copies get the same treatment.
http://www.finewoodworking.com/item/372 ... -materials Doing that with groups means you have to hit each group separately. Apply the material to the outside of the group or component and you forfeit the ability to adjust the grain direction.
Again, modifying a model:
http://www.finewoodworking.com/item/362 ... ng-a-model
Modifying the parts.
http://www.finewoodworking.com/item/356 ... d-chamfers In this blog post I was adding stopped, curved chamfers to a parts of a hayrake table. Because I used components instead of groups, I was able to make copies of them and move them away from the rest of the model for editing. Then I deleted the copies leaving the edited originals still in place. Copying a group for editing does nothing to the original of the group so you aren't any farther a head.
You can more easily give components names compared to groups. Components get unique names by default (Component#1, Component#2, etc.) Groups are all called 'Group'. That's really handy in a cut list to have all of the parts with the same name. I imagine a cooking show where the chef says, measure out 2 tsp of stuff and put it into a bowl. Stir in one and a half cups of stuff and beat it until fluffy. Next add one small packet of stuff and fold that in gently...
Adding materials properly, again:
http://www.finewoodworking.com/item/237 ... your-model
