Single Wall vs Twin Wall flue for section inside house? Pros and Cons...
Krome10
17 May 2012
South West Wales
Hi
Back again with a second wood stove query, if anyone would be kind enough to share their thoughts please...
We're planning to have a stove fitted into a single storey room. The stove has a 5" flue. The installers who have quoted said they think the flue will need to be a total height of 4.5m. It will be a straight run, no bends. If there were to be a single wall flue in the room up until where it has to change to twin to pass through the ceiling, the single wall section would be around 1.6 to 1.7m. The rest would be twin wall, although most of it would be outdoors.
We only burn well seasoned hardwoods.
From what I've learnt, the advantage of single wall would be more heat to the room. One installer said he thinks for each 1m of single wall flue you get 1kW of heat, which would be a great bonus. I'll also admit a bias - I think the stove looks so much nicer with the single wall 5" flue. I've only found a couple of photos online where the same stove has been installed with twin wall and to be honest I think it looks f-ugly. Also, more space on the stove top for a kettle etc would be an extra bonus.
However, I've also learnt that the advantage of twin wall is the flue maintains a higher internal heat, creating a better draw, which results in a stove that is easier to start, runs better, and a flue that doesn't block with creosote so much. (Although I should add that some say they have none of these problems with single wall).
It seems to be a very divided topic, with strong opinions on both sides. While I want the aesthetics and extra heat to sway me to single wall, I also don't want a stove that is tough to light and doesn't run well.
So over to you guys for some thoughts and insights...
Many thanks
Might be an issue if you burn resinous softwoods as the resin will condense on the cooler single wal but for hardwood I doubt it's an issue?
I would go for single flue in the room, only switching to double flue at the transition through the ceiling and upwards, as has been suggested. You will get the benefit from the extra heat in the room coming from the flue. I don't think that the other considerations are necessarily worth worrying about for such a short length of single wall.
What is probably more important is easy access to cleaning the flue which has to be done regularly. The stove I have in the workshop is more easily cleaned from above by passing a brush on a rope down and pulling it into the stove. It is single wall throughout and needs cleaning every year.
The one indoors has a double flue that passes through two stories and can only be cleaned from below. This necessitates removing the metal baffle plate in the stove, which can only be done by first removing the insulating cheeks . These invariably fall into pieces and have to be replaced either in full or in part. So, I'm happy if I can get away with a proper clean of the flue every 2/3 years only.
Best do without a wood burning stove as they damage health in pernicious ways.
But this to the side.
As you mention, a double-wall flue will keep the hot gases from precipitating out more tars and other gunges on the inside of the chimney, which deposits can become a chimney fire cause. Even dry hardwoods will eventually deposit such stuff if the smoke and gases cool too much before exiting the chimney top. Single skin chimneys cool rapidly as they heat up the house air.
Another danger of a single flue in the house, as I can attest from bitter experience, is that it can impart a serious burn if you inadvertently touch it. Fall against it in such a way that it takes a second or three to get off it and you'll probably be in hospital.
But a single flue can, as you say, impart an immense amount of warmth. I once rented a cottage with a tiny coke-burning stove in the cellar-kitchen. The chimney passed up through another three floors (single room per floor) and heated the whole house with not much coke. It was a 4 " diameter cast iron chimney so got very hot. It was this chimney that taught me about how well such a thing can sizzle a human. It also had to be cleaned about every three months, even though coke burns very clean.
I believe it's usual to have a sigle skin for the first length. Excuse poor photo.
    143.6 KB
You have to comply with the HETAS regulations and the install is notifiable. We have just had one installed and used single wall from the stove into twin wall, the change from single to twin has to be 450mm below the ceiling but to make this transition more appealing you can use one of these from Dura flue,
https://www.directstoves.com/dura-flue-single-to-twin-wall-conical-adaptor-in-black-150mm.html
In fact I would use all Dura flue twin wall pipes as they are really good quality with sound connecting bands. Our stove fitters said that using single wall from the stove does allow more heat to radiate into the room, using twin wall you get no heat from the flue so lost heat. Our flue has a total length of 4.6 metres and has a good draw, there were no concerns over flue gas temperature and single wall does look nicer.
I assume you have a flat roof ?
We are in a bungalow and have only enough flue to clear the roof apex. The regs also covers these dimensions.
When looking for parts there are some really flimsy brackets around, we used these and can say they are really solid and well made
https://www.directstoves.com/dura-flue-roof-support-in-stainless-steel-200mm.html
Not really - the single wall is where it's hottest.
The single wall is hot on the outside, where it loses heat rapidly (and burns the unwary toucher). With a double wall chimney, the great majority of the heat stays in the chimney, so the inner part is hotter than would be the inner side of a single skin chimney with the same fire beneath it. This being so, the double wall chimney will see less tar and other solids precipitate out of the gas and smoke on to the inner chimney walls than would be the case with a single wall chimney.
Double wall chimneys generally have insulation between the outer and inner chimney walls, which keeps the heat inside and prevents accidental chimney touchers from getting their person quick-fried. They also stop the chimney heating up any chimney-claspers or the 'oles that the chimney passes through in the house walls/roof.
Many thanks one and all for the helpful replies :)
@Jameshow – just well seasoned hardwood here. If we ever were to use softwoods, I would make sure it’d been seasoned for a good few years, and would also make sure I burn it alongside hardwood.
On our existing stove, I often turn the stove up full whack when I put the last log on, in an attempt to clean up the inners of the flue
@niall Y – That’s good to hear. The more people who think single wall would be fine, the better! It’s a tough choice when it comes to form over function, and this single wall vs twin wall all-the-way debate has certainly got strong proponents in each camp.
The stove we’re planning to get has easy access for sweeping. Just have to remove the baffle plate, which can be done one handed and without having to remove any firebricks nor anything else first.
@Eshmiel – Thanks for the safety warning. It’s just the two of us in the house, no kids, and a dog that’s short arse enough that the flue will be well out of reach. The stove will be in a corner and has a reasonable depth to it. And the flue outlet is quite near the back of the stove. So with all that in mind, I feel the flue will be tucked well out of the way, and the stove itself is probably more of a risk.
Regarding your other points, they summarise the pros and cons of each position well. Which doesn’t make deciding any easier!
@Phil Pascoe – Yes, I agree, you see that a lot in stove installations. Tbh, I’m not that keen on the single going into twin below the ceiling, but still prefer the look of that compared to twin wall all the way
@Spectric – We will be using a HETAS installer. Thanks for sharing your experience (and for the links). Good to hear you’ve had no issues. So does your single wall go into twin wall 450mm below the ceiling? Do you have high ceilings or standard/normal?
No, we have a pitched roof.
Thanks again for all the help everyone.
Any further thoughts from forumites always welcomed :)
Yes that is a HETAS requirement to do with single wall pipe and combustables, single wall has to end 450mm from the ceiling and become twin wall to transition through the ceiling, you used to get a very ugly transition before you could get the conical adaptor but it now looks ok. Our ceilings are normal height.
Hi
I have not been able to find a photo on line with one of these installed. I can only find the photo of the piece itself on the product page. If it is not too forward of me to ask, I wondered if you would be happy to share a photo your flue with the conical adapter so I can get an idea of how it looks fitted?
No worries if not though.
Ta
Hi @Krome10
Our woodburner is in a corner so that it faces out into the middle of room rather than on one of the two walls, there is an offset using two 30° bends to keep the flue between the ceiling joist above and as yet have not got the ceiling plastered hence the tempory fixings for the flue plate.
Single wall thick steel up to the ceiling (less 450mm) and twin wall thin stainless with insulation between, thereafter. Twin wall also transmits a fair degree of heat so it makes good sense to have that on the inside, through the room above if there is one, either through a vented box (air in bottom, out top) or shielded with perforated metal, to allow heat loss (into the room) but avoid hot points.
Having the flue on the outside is a big waste of heat.
The main thing for efficient burning is to forget "log" burning but burn stuff reduced in size as far as possible, which ends up as a compromise between fast efficient clean burning and frequency of re-charging. Slowly smouldering logs not a good idea.
As you can see the transition from single to twin wall is not a step change which I think looks awful and the conical adaptor smooths everything out.
This is an important point for woodworkers generating shavings, sawdust and chips. Most stoves will not make the best of these and some will become dangerous if charged with sawdust or shavings as they go WHOOOMP! But there are better designs.
I once had a summerhouse at the bottom of the garden that was very pleasant to be in but bluddy freezin' for several months of the year. A wood burning stove was the obvious answer. How to avoid polluting with that smouldering-log syndrome; how to avoid paying for logs at all, to burn?
There was a design of stove available that had a pipe thingy internally, with an arrangement to control the burn via the air inlet, which ran from the top of the stove to the bottom, internally, with an inlet valve to control the amount of air fed to the burn and the internal-pipe air exit at the very bottom of the stove. This arrangement allowed the burning of sawdust and shavings, preventing any WHOOOOMP by means of limiting the air fed to the burn.
I can't recall the name of the manufacturer; and it was 15 years ago that I bought & installed it. It belongs now to the person that bought that house.
It worked very well indeed to make a hot, clean burn of dried sawdust and shavings. It could be turned down to a very low heat without creating any smoulder-smoke.
    238.5 KB
Basically you can't put dust/shavings into an already burning stove or you might get blowback.
So wait for the fire to go right out and then refill the stove packing in as much as you can, and light it at the top. Some shapes of stove are better for this - tall straight sided worst, short and wide better - for more surface area on top of the heap, to burn. Dowling Sumo near pyramid shape the best, but not cheap. Air inlet needed to top of stove to burn top of heap - with the Dowling this via the gap between loose fitting glass and the door.
