Um, yes and no. Side rebates are really there if you need to tweak the fitting of a housing, if for whatever reason you can't adjust the thickness of the the other part. Veneered or already finished shelf, for instance. They work well, but it's a bit of a fiddle and less frustrating if you can get your initial cutting good enough. As Andy says, if the hairiness is within the housing, it's unlikely to be an issue anyway. As long as you knife your edges with a nice firm score line - with a sharp knife!
- then you should be okay.
Saint Simon":226dppca said:
Does anyone have experience of these to pass on, of which models work best and how difficult is the blade adjustment to achieve fine even cuts? Is this easier with separate left and right hand models?
Having said all that, when you find yourself with a side rebate plane job, it can be a lifesaver. I, er, um, have the L-N 98/99s, a Stanley 79
and the Veritas jobbie. Of the three, the Veritas is far and away the most comfortable to hold while the L-Ns are probably the most awkward (particularly if you have larger hands, I would imagine). The Stanley is easiest to change direction with, assuming you leave both blades set. If you retract the trailing one, and some people do and some don't, then obviously it's no advantage over flipping round the fence on the Veritas. Having to store/carry/find amongst the shavings on the bench two planes in the form of the L-Ns may or may not be considered a problem. If you want to cobble up an angled fence for trimming dovetail housings etc, then the Stanley's fence is probably the most friendly, and its long length gives you plenty of registration all the time, which is quite nice. You do need to watch that you set it parallel mind you, but that's not hard. All three are pretty fiddly to set up, but the Veritas does at least have a sprung lever cap which holds the blades as you adjust depth of cut. For a mechanically adjusted depth setting you'll need a Preston 1369, iirc. (Good luck with that...) Both the Veritas and L-Ns will cut to 1/2" deep in as narrow as a 3/16" slot, but iirc, I found the Stanley can go a little deeper. For looks, the L-Ns win all accolades. And why do I still have all three? The Veritas because it's the most comfortable; the L-Ns for sentimental reasons (My First L-Ns - awwww) ; the Stanley for when I ever get round to needing an angled fence and possibly (iirc) that marginally great depth. ...
