Phil Pascoe
Down to misquotes now?
woodbrains":2dtup4aj said:Hello,
Japanese chisels and plane irons are not HSS (there are a few modern and not particularly good exceptions) and the steel is much harder and more brittle than spindle knives etc. so the comparison does not hold up. The softer back of Japanese tools is meant to support the very hard steel cutting edge and should be honed with a flat single bevel to maximise strength.
Mike.
James-1986":2o7az9ue said:Seems like a good comparison to me, hard metal laminated onto soft metal! Decent HSS is 60 to 65 on the rockwell scale so hardly soft, and you know when you have a hard bit as glue lines etc don't chip it. How much hardness increases as the numbers go up on that scale I don't know. I also have a big pair of blank moulder knives which are TCT laminated to tool steel which are hollow ground, harder than white steel. Its hard to say which is more brittle unless you know the exact blend.
As the tool has a bevel on the end, the softer steel is no where near the cutting edge to support it anyway. Unless we're talking about a big chunk snapping off?!
You don't seem to understand what I'm saying Mike. Steel is required behind the edge in any tool, not just the Japs. The slightly convex bevel which is the accidental result of my lazy but quick sharpening will remove steel from the heel of the bevel to some extent. Better than hollow ground where the tool is thinned nearer to the edge..woodbrains":1tzcv456 said:Hello,
For the same effective cutting angle, convexity must remove steel behind the cutting tip, exactly where it is required in a Japanese tool. If we are being true to the nature of the tools. Jacob's rounding under method relies on the fact, otherwise the cutting angle would increase; a condition that he denies happens in his tools. The soft backing steel is there for a purpose, so removing it defeats the object.
Hollow grinding, if one measures the angle the tool makes with the stone, also removes steel in the supporting area, though it should be noted that this will produce an angle on the tool somewhat lower than measured at the tool rest. A bit of experimentation will correct the tool angle and results in more steel in the tools bevel.
Mike
G S Haydon":2106l24t said:"Hello,
There is a difference between hardness, brittleness, toughness, wear resistance etc, etc. also, HSS is resistant to losing its temper during grinding; high carbon, low alloy steels are not. There is little in common with machine knives and handtools, even grinding angles are different. Planer knives might be 35 degrees, japanese tools less than 25 . The comparison is really non existent."
but not so long ago we were discussing where we were discussing edges we said
"I still don't see why a spindle cutter will dull any differently than anything else. Perhaps a variation in degree, but a completely different mechanism altogether is not likely. Micro fractures in the grain structure of metals exist, the wood is the same, the colossal forces at the cutter tip are of similar order. Why do we feel that hand tools will behave differently? And if so, someone else prove it, I have read what I have read."
I hate to be a "tool" and mention the above but sometimes we all make this a heap more confusing than it needs to be (or quite possibly I'm to dim to keep up ). Mike, I like your posts a lot so forgive me if this seems personal, it was just an example.
I think Richard Jones has good take on the situation and I don't think Jacob has any issue with maining angles with a rounded bevel. I'll hold my hands up and say I was less than convinced his was the most legit way but that's the problem. Thinking something has to be "legit" and relying only on the text and not on experience at the coal face. Equally Mike your approach is proven and works. The only evidence required is how skilled folks get results. What we can take from this thread is that Japanese Chisels can be hollow ground, flat ground, secondary bevelled or convexed and still turn out great work!
You just don't pay attention Mike.woodbrains":1p67s01g said:....
So now Jacob is not intentionally arm flapping to get a convex bevel anymore, but accidentally doing it whilst trying to hone a flat? His bitchin all these years about rounding under has just disappeared into the ether then! ....
David C":2z5x8tyz said:I have never found a problem with hollow grind, Though Tormek has 10" wheel so hollow not very great.
I can't remember a faliure in use in the last 35 years
David
CStanford":35tt6pxj said:The more interesting question is why Japanese craftsmen are so utterly opposed to hollow grinding.
sdjp":3sjadh17 said:....consider the materials that were used for sharpening. Most of the good naturally occurring stones in Japan were softer than western ones, and this leads to two separate effects. Firstly, they are faster cutting - so the point at which you'd want more mechanical assistance is larger. Secondly, these softer stones are not quite as strong - meaning that for a naturally occurring stone, you face two issues. Getting a large enough piece to make a wheel is more difficult; and they are more likely to shatter. Not necessarily a lot more likely, but I submit that it would be enough to discourage this process, relative to other places.
CStanford":r3c3synb said:Is anybody aware of a book or article, in translation or otherwise, where a professional Japanese craftsman (not a Western hobbyist) states the case for a flat grind? This isn't to say all of you aren't probably right, but do we have anything from a horse's mouth?
