Ran into a problem today making replacement shelves for an alcove in what's soon to be my mother in law's house. The previous owners took their shelves and brackets away with them but left three lengths of twin slot supports on the wall. Easy enough, I thought, to replace the brackets and scribe new shelves into the space. In anticipation of a LOT of books, I have got 18mm ply which I'm going to beef up under the front edge with a 16mm thick batten and dress the join on the front with a D moulding.
Imagine my surprise when I started templating today and found that the middle support is higher than the side ones! Not just a bit out either, the resultant gap at whichever end is tipped up is about half an inch. This presents something of a problem and an urgent second think.
Possible solutions....
1. Outer supports are near enough level -> scrap centre support entirely, sagulator indicates this could work but would have to be careful about load
2. Remove centre support and move outer supports closer together to distribute span more evenly (alcove is 1800 mm and current supports at centre and about 150mm in at each side)
3. Reposition centre support- if fixings are asymmetrical I might be able to flip it end for end and keep it centred while finding solid locations to drill new spots in the wall, otherwise move to one side and accept loss of symmetry
4. Scrap the adjustable element and use battens all round the alcove instead
5. Pretend I didn't notice and have shelves with a frowny face
6. Cut a housing for the middle bracket in the underside of each shelf- possibly the easiest fix provided the strength was still adequate.
I think option 6 might be the least sweary. What I also learned today is my 600mm level isn't long enough. Given a raft of other tasks coming up I'm not sure whether I'd be better off looking for a longer level (Stabilo?) or a self levelling laser that would let me get a line right across a room - likely use for decorating and fitting furniture/storage type tasks rather than framing or construction.
Any thoughts on this and whether I could get away with cutting out a third of the thickness of the shelves over the middle bracket would be much appreciated.
G
G
