Hi guys
Some of you guys may or may not know that I was planning to build a shed to mainly do my weights in and to also have a small work bench in if there's enough space. Well I eventually got round to starting it. It's a 5x2.8m shed and all framework for floor, walls and roof is from reclaimed pallet wood.
I do realise that things haven't really been done exactly how they should be, so go easy on me Though I'm not looking to build a mansion or anything Just somewhere whereas I can spend an hour every other day doing my weights. Also, I'm building this within a tight budget and if I were to get 3 years out of it I'd see it as worthwhile.
We built the frame first and then concreted the base posts in afterwards. The frame as it sits isn't touching any ground below or on the outside edges. Though, it is running slightly below ground level as you reach the right hand side. I'm hoping water doesn't get below the frame and if it does, it soaks in rather than creating a massive puddle that will eventually touch the floor.
As you can see I haven't used any ground sheets..maybe I could find some gravel on the cheap and spread it over the soil?
The osb board you see is 9mm and is roughly half cut sheets. They are 2.4x1.5ft x 60 sheets and 1100x1200 x 30 sheets. All square cuts. They were advertised on gumtree and I managed to get the lot for £140. I will use these to board out all of the inside except for the floor. Maybe double them up for the outer roof as well.
With the long cuts of osb board I have, it means my studs for the walls will roughly be at 18" centres. Lots of joints but a lot cheaper than buying full boards.
Anyways that's where I'm at so far
