Finally, got around to pulling down the old rotten shed that was in the house when we bought it, only to find this mess...
Not sure if it's clear from the pics, but the rubble/stone is well above the level of the path in front of it.
Plan before it came down was to lay a concrete base for a new shed/workshop, I figured it was probably soil under the shed, didn't expect all this!. Problem is clearing all this by hand first, as access is limited there's no other option. It's a big space, Ideally like to build a 10x18 structure.
My first thought would be what other options for a base given the mess? Just seems to be a huge task to clear all this and dig down from level!
Second thought was could I level this rubble some how, using it as hardcore and lay the concrete in a tall timber frame, it would end up about 8inches above level tho! OR is digging down a requirement?
The old shed was sitting on these sleepers, they weight a ton, could maybe be reused for the same purpose, (with a damp membrane this time)?
Any thoughts? Thanks
