Sharpening
Yes I know you can but you have to choose to do it and think about it. Or buy yet another gadget add-on. Or even break the bank with a set of "Odate Crowning Plates" £100 each https://www.popularwoodworking.com/toolreviews/odate_crowning_plate_sharpening_stones/ :oops:
Freehand on a typical oil stone you are very likely to get a camber whether you like it or not. You might not be aware of the need, but luckily you get one anyway!
So what your saying is you can’t sharpen a non cambered blade…
I don't do much woodwork these days. I've become allergic to wood dust, particularly hardwood. Probably become sensitised.
So I came to my "rough" smoother to trim up some ends of some decent softwood I was using yesterday. Looked at the blade for the first time in ages, it was all OK been stored indoors, but the blade really wants regrinding. I wanted to use it, so a couple of licks on a fine Trend diamond stone, and a quick strop on a handy bit of softwood, brought it up to sharpness good enough to take shavings off the end grain of softwood. Job done.
I'll grind the blade when I have a minute.
I want to do the job, not fiddle about with jigs and machines that don't IMHO do a good job of real world sharpness anyway.
It's a woodworking plane. Not a helical gear cutter for a mill. Hand sharpening should be sufficient in 99% of cases.
Nope. I can sharpen a straight edge if I choose to. The secret is to look at what you are doing and adjust accordingly. It's a useful crafty trick in woodwork and many other areas. :unsure: Not many people know this!
And there was me thinking you have to keep looking at the camera to engage with your audience at least that’s what all the woodworkers I see keep doing.
I swear you're getting more sarcastic by the day @Jacob :ROFLMAO: (y)
Years of practice!
But it really is an issue - it come up all the time; people ask about design details, how to make a table etc. and one has to suggest that they go and look at a table! There's usually one or two in the vicinity!
Comes up often if you forget to measure something for a job or forget to look at it and hazard a guess. Can be out by a large factor - that door jamb you guess to be 3x2" turns out to be 4x6" and so on.
Looking at things, or how your job is progressing, could be very useful, even for modern sharpeners with every gadget under the sun!
So I asked Microsoft's one that and got this:
AI solutions for sharpening tools can vary depending on the type of tool you're referring to. Here are a few examples:
  1. Knife and Blade Sharpening: AI systems can be used to automate the sharpening process for knives and blades. These systems can store and recall the unique requirements for various knife types, adjusting the sharpening angle and technique accordingly. This ensures each blade receives the specific care it needs, enhancing its performance and longevity
  2. Image Sharpening: AI-powered software can enhance the clarity and detail of digital images. These tools use advanced algorithms to analyze and restore lost information, resulting in sharper and more visually appealing images. Examples include Topaz Sharpen AI and Luminar Neo
  3. Industrial Tool Sharpening: In manufacturing, AI can be integrated into CNC (Computer Numerical Control) machines to optimize the sharpening of industrial tools like drill bits and saw blades. AI algorithms can monitor the wear and tear on tools and automatically adjust the sharpening process to maintain precision and efficiency.
Yebbut, people are lazy, so you get this instead :ROFLMAO:
Honestly, you couldn't make it up!
All rebate type planes require straight edges,
Yes no problem. Straightish will do. The typical camber curve on a jack plane would only show as a tiny fraction of a mm at narrow width of a rebate plane.
match planing requires a straight edge,
Not at all. Depends on your technique. Mine is to square/straighten edges as per normal, (machine or hand) but then to match plane each joint e.g. across a table top, by standing each board vertically on the next one, one pair at a time to see how they fit, and then plane to match perfectly by taking off a little here and a little there. The camber is particularly useful here as you can plane to one side or the other to alter a slight bevel either way. I find this much easier than trying to get every edge dead straight and square before trying to join them (if that's how others do it, I don't know). Have to mark them, as any swapped around edges almost certainly would not fit each other
oh and let's not forget chisels.
Chisels don't need to be perfectly square. Why would they?
The obsession with perfect squareness/flatness/angles is not solved by using jigs and precision approaches, quite the opposite it is caused and made worse by them - you can't easily sharpen anything if it is not already close to the parameters of the modern sharpening kit - you have to adjust your funny edge angles to fit the kit instead of just doing it!
It's so much easier without all the clumsy modern sharpening kit and mysterious rituals. If precise squareness is needed then it's no problem anyway.
Anybody ever bought the Odate Crown Plates? I thought they were about the extreme limit of modern sharpening craziness and everybody might have started to have doubts by now!
