mark w
Jacob you have just discovered a technique you have never used and now you seem to think you can talk about it with authority, leave it alone and stick to what you think you know.So I have an old table in front of me about 6ft long with boards about 5/8" thick. Would you have "match planed" these successfully in one operation, without then having to adjust fit?
The kitchen tables I make have thicker sycamore tops say 7/8" which doubled up to "match plane" would give you about 45mm. Would that be "match" planeable?
In answer to your question, as I said before, the only restriction is the thickness of board, if you know what you're doing that is.
If the boards can be satisfactorily clamped together I see no reason why a 6ft board can't be planed in this manner. 1800mm is the longest I've match planed to date.
