Jacob
What goes around comes around.
Straight edges and simple spindle gouges are really easy to freehand, and it's the best way as you can keep refreshing the edge as you go, with very little interruption.An interesting read as I'm just trying to revive my limited turning skills which inevitably means revisiting my even more limited skill at sharpening the tools. I have an elderly Electra Beckum bench grinder and the Axminster grinding jig below. Had them for years. Works ok for flat blades but was rarely used as my chisels and plane irons rarely warranted grinding. Since returning to a bit of turning I'm faced with grinding turning tools. Works OK with some tools, but gouges are very much 'work in progress'.
https://www.axminstertools.com/axmi...68I9b7DCshu-YhtL6pitX0Ti6_t4waWRoCqCYQAvD_BwE
Bowl gouges less so, but not impossible.
Handy to have a sanding disc on your out-board end then you don't need any other sort of powered grinder.
I had a Pro-edge briefly but decided it wasn't paying its way.
