ByronBlack
Jacob, any chance of a video of you demonstrating this?
Byron, can't do it haven't got the kit. My kids have though, I'll try and get them on the job.ByronBlack":1ftaaaeg said:Jacob, any chance of a video of you demonstrating this?
javali":1hxk782i said:I do not know about you, but I get a mirror finish, I love the way my bevels look, and they do shave the hair off my body. I have no idea how thick the shavings are.
Mr_Grimsdale":20ns4a9k said:A rounded bevel means starting off cautiously at 30 deg, but after a few mm then dipping slightly at which point you throw caution to the wind and can press down hard and stab the chisel forward quickly and energetically.
Bugbear I think you've got itbugbear":19d3tkit said:Mr_Grimsdale":19d3tkit said:A rounded bevel means starting off cautiously at 30 deg, but after a few mm then dipping slightly at which point you throw caution to the wind and can press down hard and stab the chisel forward quickly and energetically.
... and achieve nothing except altering the relief angle for the next sharpening. What a waste of time!
It is self evident I agree, if you are a "double beveller" that is. If on the other hand you are a "rounded single beveller" it saves time and is easier. Bigger blades or chisels still means moving up a grade or two however, but grinding also a rounded bevel ('cos it saves time and is quicker).I see no benefit in working at an angle below 30 for any abrasive other that the first (coarsest).
No "double beveller" would dream of wasting time working the primary bevel with a fine grit - this seem self-evident.
Err, dunno, praps :lol:Perhaps the rounded bevel obscures this truth.
BugBear
Mr_Grimsdale":2x5zf1pi said:Bugbear I think you've got itbugbear":2x5zf1pi said:Mr_Grimsdale":2x5zf1pi said:A rounded bevel means starting off cautiously at 30 deg, but after a few mm then dipping slightly at which point you throw caution to the wind and can press down hard and stab the chisel forward quickly and energetically.
... and achieve nothing except altering the relief angle for the next sharpening. What a waste of time!"altering the relief angle for the next sharpening". A waste of time yes - until you come to "the next sharpening". And done in one step instead of two. Is also "altering the relief angle for the next" pass during the current sharpening, which is what speeds things up so much.
So it's win win - you have only to look a few seconds ahead to see what the gain is.
Benchwayze":opg4n9ds said:As to my test, the fact still remains, both chisels had the same test. The rounded part of the curved-bevel chisel showed crushing of the fibres. The other showed a cutting action on both sides.
Just out of curiousity, how many of your blades have reached the end of their useful life in the past 10 years? How many times a week do you sharpen a blade?bugbear":opg4n9ds said:Conversely, any stray steep strokes when using the coarse abrasive will remove far more material than is desirable from the precious tip.
javali":1zzimwoo said:For the record, the grinding angle was 50 degrees, and we all know that it is not the best bevel angle for a Stanley #3
So, do we agree that flat bevel is better for chisels while round bevel is essential for planes? :roll:
Just out of curiousity, how many of your blades have reached the end of their useful life in the past 10 years? How many times a week do you sharpen a blade?bugbear":1zzimwoo said:Conversely, any stray steep strokes when using the coarse abrasive will remove far more material than is desirable from the precious tip.
Strewth not sure if I can keep this up :roll:bugbear":2wo5moz0 said:Mr_Grimsdale":2wo5moz0 said:Bugbear I think you've got itbugbear":2wo5moz0 said:Mr_Grimsdale":2wo5moz0 said:A rounded bevel means starting off cautiously at 30 deg, but after a few mm then dipping slightly at which point you throw caution to the wind and can press down hard and stab the chisel forward quickly and energetically.
There's clearly no point dipping/rounding/dubbing below 30 degrees when using an abrasive too fine (and thus slow) to create any useful relief. Any such strokes are simply wasted, regardless of "vigour".
Well yes - as I've pointed out - one grit only will work for smaller edges, bigger ones may need 2 grits. So it is a variant if you like. But it works a lot better because it's quicker and easier.Conversely, any stray steep strokes when using the coarse abrasive will remove far more material than is desirable from the precious tip.
If care is taken that strokes when using the coarse abrasive are kept in a "lowish" range, and strokes when using finer abrasives are kept in a "highish range", all will be well.
Of course, at this point, we're simply talking about a varient of good ol' double bevelled sharpening.
BugBear
Bugbear - I thought you had carefully read every word I have written :shock:But in double bevel sharpening, either hand or jig, one NEVER (deliberately...) uses the coarse abrasive on the tip, whereas (as I understand it) Jacob's approach involves deliberately doing exactly that.
Mr_Grimsdale":uhvi4laa said:It's no good coming up with arguments about why it won't work when it self evidently does work just as I've described, for me at least. I suggest you stop worrying about it - you do it your way and I'll do it mine![]()
Well I had to be carried off screaming from here to the sound of slow hand clapping, and I wrote it up here (needs up dating I see). Not sure if I've anything to add.bugbear":205mkh34 said:Mr_Grimsdale":205mkh34 said:It's no good coming up with arguments about why it won't work when it self evidently does work just as I've described, for me at least. I suggest you stop worrying about it - you do it your way and I'll do it mine![]()
Interesting approach to a discussion forum, but since you want to stop...
BugBear
You are absolutely right. We also know that a chisel honed at 40 degrees tends to crush wood fibers more than a chisel honed at 30 degrees. If John is allowed to ignore the honing angle, I am taking the same liberties.bugbear":3bklvwmf said:javali":3bklvwmf said:For the record, the grinding angle was 50 degrees, and we all know that it is not the best bevel angle for a Stanley #3
Assuming we're talking about a bevel down, 45 degree frog sort of #3 (i.e. a normal one) a 50 degree tip bevel will indeed skid, no matter how it was created. This is because part of the blade behind the edge is lower than the edge, and will hit the wood first. (draw a diagram).
bugbear":3bklvwmf said:My concern is not "using up" the blade.
Except for possibly "using up" the blade faster, why is it more important?bugbear":3bklvwmf said:I never use a fine abrasive on the primary bevel (no point), and I never use a coarse abrasive on the secondary (too fierce).
The former point is not critical, the latter is more important.
