A
Anonymous
Guest
Answer is simple - you don't aim at getting a consistent dip. You don't aim at a dip at all, its more a case of relaxing, not trying to maintain a fixed 30deg, but having a bias towards dipping down so that you are backing off the back of the bevel slightly, every time you hone the edge.ByronBlack":2y46prss said:javali/jacob - alter ego?
BUT if I wanted to use the rounded bevel - how would you recommend to someone the process of getting a consistent 'dip' as you hone?
It's a bit "Zen and the Art of Sharpening".
Eventually you might have a rounded bevel like this one below but only after very many honings. This one below had a big chip so I had to regrind it (using belt sander) or it would be years before it looked like this.
If you start rounding the bevel on a new or conventionally sharpened chisel you will hardly see it at all except eventually the heel of the bevel will be touching the stone as well as the edge.
It's dead easy to do but quite difficult to describe.
Another detail is if you want a really scary sharp edge you hone the rounded bevel way as I've described, on your finest stone, but in very short gentle strokes just a few mm, turn over and ditto with removing the burr. The idea being that each time you make/remove the burr it is smaller than the time before. This is particularly difficult to do with a great clumsy honing jig in the way.
Thanks javali, glad to hear it works for you. Not me under assumed name, or anybody I know, honest :lol:
cheers
Jacob
