Sharpening for beginners
Agree with above, for my first couple of years I had every gadget and gizmo known to man. Now I have an India stone, and Arkansas stone and a strop.
You just have to understand what you are trying to achieve.
The most exquisite furniture and joinery ever made was made with traditional tools sharpened on locally available stones.
Some great responses above, thank you. I will be studying all your suggestions and the videos etc later today and trying them out.
I'm really not sure about hard or soft metal in my chisels, but one is at least 60 years old and the others are more modern but cheap and I've not got a good edge on any of them . Been trying to sharpen a small swiss army penknife blade without success.
I'm enjoying woodworking as my retirement hobby. Previously I only did it for DIY odd jobs around the house. I'm now making some very pleasing stuff on my lathe, using carbide, so no sharpening needed, but I want to improve my skills and branch out into other projects. I realise that having sharp tools is the key to my progression, so I really need to gain sharpening skills first.
Soft metal sharpens more easily, blunts more quickly. Not the issue.
Peter - just try to picture in your mind the shape of the edge when applying different stones at different angles.
Imagine if you just had one stone.
Etc.
Soon gizmos become redundant.
I sighed at your description of how your hard work hasn’t brought forth an edge. Not your fault at all! It’s the pundits of these ridiculous stones in their thousands of grit.
For hundreds of years and as is still the case the people who have made all the furniture you see only ever sharpened to about 400 on a combination stone, maybe if they needed to they would strop a bit as well. As a commercial bespoke furniture maker that’s all I have ever done, and @Jacob and @Amplidyne say the same.
It really is quite simple and inexpensive, a Norton India combination stone will cost about £40? Plus a little thin oil. Put the sloping edge of the blade on the oiled stone and then lift it a fraction till the oil squeezes out then rub up and down at that same angle with medium downward force, after 10? rubs up and down feel the back edge and you should feel a roughness at the edge, this is the wire edge, to remove that put the back of the blade flat onto the stone and rub up and down just a few time with pressure keeping the blade flat on the stone, the wire will either have dropped off or is ready to, once it has gone that’s about it, I then have a habit of stropping it on my jeans but probably not needed tbh.
We are only cutting wood. It’s not Rocket science and as I’ve described will be quite sharp enough.
A picture to prove my point and credentials.
I missed out that I used to strop on a piece of leather drive belt dressed with fine valve grinding paste. Get an edge that will shave hairs off the back of your hand.
I generally use a fine-ish diamond stone now, and strop on what's handy, but I don't do as much woodwork these days, and what I do is softwood.
We were shown how to sharpen in woodwork class as boys.
Personally I think that there is a market that has grown up around sharpening, and all the gadgets and techniques, and sharpening has almost become an end in itself rather than a simple means.
My advice to beginners is to learn to sharpen by hand without any guides, jigs or multiple levels of grit. As said, an India oilstone or a good quality fine diamond stone will get you there. It will save you loads of time to be doing what you actually want to do. Woodworking.
That's a very nice piece of furniture incidentally.
