never heard of triangular rods and I've always sharpened my serrated knives with a steel, just like any other knife. It works perfectly and I've never had the slightest problem slicing bread etc etc...... If you wonder "why triangular rods, not round ones like some others ?" It's because there are a lot of serrated blade knives out there and those need to be maintained too.
Yup.Butchers steel all the time but they still have their knives sharpened regularly.
Book? Not just a book but a veritable bible! Will it have an old and a new testament? Will there be centuries of analysis and comment attempting to reconcile the two? It'll provide entertainment - and even careers - for many, many down the years.When does your book come out Jacob?
3 pages of preaching followed by another 97 repeats.![]()
No, there'll be no New Testament.Book? Not just a book but a veritable bible! Will it have an old and a new testament? Will there be centuries of analysis and comment attempting to reconcile the two? It'll provide entertainment - and even careers - for many, many down the years.![]()
Modern sharpening theory again. It's nearly all nonsense. I could do a demo to show the swarf on a clean cloth but I can't be bothered!.....
The more or less universal opinion, generally backed up by observation of the edges with a magnifier, is that a steel bends the serrated parts of a knife edge back into line rather than removing any metal...
You are being brain washed again!I suppose that, like any abrasive process, frequent use of a steel ( almost at a "cut once, steel 10 times" rate) might remove metal. It seems a very laborious way to do so, though.
Can do after using the same knife and steel for 40 years or so, but still cuts just as well.And it produces those rather wonky caved-in blades.
Didn't bother reading the links, there is too much of this stuff!......
Certainly buy a better tool if you want to, just don't be put off the simple ways or talked into doubting your own ability.As Jacob remarks, diamond dust and so forth were not available in them olden days, so butchers and fish gutters used the steel as they had nowt else. Does this mean that sharpening folk should never adopt an improved method or tool?
Back to oil stone for woodwork and knives too if in need of serious remedial work. But for daily routine just the steel for a knife.Back to the cathedral step with them!![]()
I just won my bet with myself on what Jacob's next post on this thread would say.Modern sharpening theory again. It's nearly all nonsense. I could do a demo to show the swarf on a clean cloth but I can't be bothered!
*Snip
No there isn't that much to say. It's the modern sharpeners who make an industry out of misinformation!Book? Not just a book but a veritable bible! Will it have an old and a new testament? Will there be centuries of analysis and comment attempting to reconcile the two? It'll provide entertainment - and even careers - for many, many down the years.![]()
This was my understanding too and I'd seen the evidence posted before to back this up. I don't doubt that there is some abrasive action of rubbing a steel edge on another bit of steel but the main action is the reforming of the edge. However, I do wonder if the two actions combine to produce a edge that can gut fish and slice squashy tomatoes. If the edges of a knife blade is serrated at the micro scale, then using a steel will realign the 'teeth' (for want of a better word) and also abrade the sides to produce a better edge. It is interesting for those that get interested in the reason for things working but it doesn't really matter if it worksOh dear - the olde wifey tales are running amok once more!
I realise that those with, let's call it, an ideological view of sharpening will immediately denounce any counter opinion found on the interwebbery as, after all, it does contain a vast array of untruths. Still ....
When one goes searching for what we might call the Jacob-understanding, er, belief, about steels it seems impossible to find any articles, vids or anything else that says that a honing steel removes metal in the same way as a sharpening instrument such as a similar metal stick coated with diamond dust, aluminium oxide dust etc.. But articles and vids stating the opposite to Jacob-belief on the matter are legion. There are dozens on the first page of search results from asking, "How does a steel sharpen knives".
I suppose that, like any abrasive process, frequent use of a steel ( almost at a "cut once, steel 10 times" rate) might remove metal. It seems a very laborious way to do so, though. And it produces those rather wonky caved-in blades.
https://kitchenknifeplanet.com/do-honing-steels-wear-out/
https://homediningkitchen.com/does-sharpening-steel-work/
https://www.thekitchn.com/did-you-know-this-steel-doesnt-actually-sharpen-knives-211855
https://www.knivesandtools.co.uk/en/ct/sharpening-steel-buying-guide.htm
As Jacob remarks, diamond dust and so forth were not available in them olden days, so butchers and fish gutters used the steel as they had nowt else. Does this mean that sharpening folk should never adopt an improved method or tool? Back to the cathedral step with them!![]()
I've never had a deformed edge. It's an abrasive action. Why do you believe this weird stuff? Where/what is your evidence?This was my understanding too and I'd seen the evidence posted before to back this up. I don't doubt that there is some abrasive action of rubbing a steel edge on another bit of steel but the main action is the reforming of the edge.
I should hope you haven't. You'd think there would a society to support people with such terrible afflictions.I've never had a deformed edge. It's an abrasive action. Why do you believe this weird stuff? Where/what is your evidence?
