Steve Maskery
After our discussion of the relative merits of cutting sheet goods like MDF on a Tablesaw (TS) v using a Track Saw (TS), I thought I'd post details of my setup and why I prefer the TS
So from now on, TS means Track Saw, OK?
This is all assuming that I have to cut pieces off a full, or at least a large, sheet. If my original blank is too narrow to support my track, then there is no problem with cutting it on the tablesaw, of course.
I have two setting gauges, one for cutting strips narrower than my track (anything from 0 up to 300mm) and another for pieces over 200mm. They both register the track from the reference edge of the workpiece, but for the narrower pieces it registers in the channel, with the cut edge towards the reference edge (so that the piece cut off is the bit I want), whereas for wider pieces the back edge of the track registers against the end of the setting gauge, which means that the track sits on the piece I want to keep.
They both take into account the width of the track and the thickness of the saw kerf.
They both have a scale stuck to them. The long one, however, does not start at 0, it starts at about 170, because that is how wide the track is. So if I want to cut a piece 1000mm long, I set the head to 1000, which is actually only 830mm from the end. But as the track is 170mm wide, the end result is that the cut takes place 1000mm from the reference edge.
The smaller one is slightly different in that the end has a T-piece on it which sits nicely in the channel.
In use, I set the width I want and use the setting gauge to position the track. I check both ends, of course. The anti-slip strips underneath means I don't need to clamp the track, but there is nothing to stop you if you want belt and braces.
To calibrate the gauges I start before I have attached the scales. Set the track to cut, say 250mm, approximately. Make the cut and measure what has actually been cut, say 248mm. Then, without loosening off the head, I slide the scale underneath the cursor until it reads 248mm. The scale is taped in place, the head removed and the scale stuck down properly.
The screw holes in the cursor are slightly elongated so that, should the scale move slightly whilst I am attaching it, I can nudge the line over a bit either way to make up for it.
It's easy, quick and cheap to make, and I would rather move a saw that weighs a few pounds than a full sheet of MDF that weighs a ton.
