settee leg commision
cornucopia
21 Jul 2008
Leicestershire
I've been asked me to make some new legs for his settee
I was given one of the old legs to take measurements of :roll:
I put some light coloured elm between centres
knocked into the round and divided up into lengths each length had its own dovetail holding
heres all 8 ready for the next stage
these legs are completely out of sight once fitted so no need for any design just strength. I mounted them in to the chuck drilled in within an inch of the top then drilled a 7 mm hole right through for the screw- sanded and sealed ready for the last stage.
I made a friction drive from an offcut
slipped the blank over it
then gently put the tail centre into the 7mm screw hole- so that i could turn away the dovetail.
heres the finished articles
Nice work,definitely better than the original.. :D
I quite enjoy a bit of production turning from time to time;there's always a bit of a challenge to make more than one of something,and get them to look the same.
Andrew
Hey George, that's getting awful close to spindle work. :wink: Nice job.
Nice work cornucopia...but see you forgot to put your
stamp on your work.....Like the way you made the friction drive
Must keep a note of that....
