Separating stud wall in garage - do I need insulation?
onionlikeapple
6 Jan 2025
Gloucester
Hi all,
Once again, budget reigns supreme here.
After a conversation in the general woodworking forum, I’ve decided I need a way to separate my gym and workshop. They currently both reside at other ends of my garage, but that’s not so great for dust inhalation.
The garage is already pretty cold, and I’m not that fussed about the stud wall maintaining/dissipating heat - I just put on a couple layers in the gym/workshop.
I’m mentioning this because I’m wondering if putting up a stud frame and attaching some plywood (with a makeshift door thrown in for good measure) would cause any issues with mould and the like? The frame would be sealed around the edges, and the door would have a stop in place to help prevent dust contamination.
Any thoughts on this? Anything cheaper I’m missing here? I’ve seen people use PVC curtains but I can’t really see how that blocks off the finer dust particles.
Thanks!
I split my garage into 2 for same idea. Used basic CLS timber for stud work, plywood on both sides, with insulation between.
Not only heat but provides a level of sound insulation too. I used ply not plasterboard as easier to hang tools off on one side and dartboard etc on other side. There is an access door, solid pine and everything caulked around edge and draughtstrips around door.
The problem I have is more with lack of air movement. No windows on gym side, gets really stuffy. Same other side but need to improve dust collection so will be fitting a vent this year and a fan vent in gym area too.
Thanks for this. Will bear the gym stuffiness in mind as ours already gets stuffy in the summer. Not against putting a vent/window in that side either honestly.
Maybe a silly question, but did you have to get planning permission or notify insurance companies for this sort of thing?
It's done as a "temporary" fitment, so I can't define it as anything other than a garage. The front is still garage doors for that reason.
Garage conversions, where the door is replaced with wall and/or windows here require planning permission.
That was what I was hoping for. Going to do some research to see if our home insurer would grumble at this but otherwise, think I’m good to go.
Might do it in parts - so this month put the stud work up and plasterboard up on one side, then tackle the rest next month.
Either way, thanks for your help :)
