d dickerson
New member
I am struggling to remove the cutterblock to either weld or buy new front casting due to a crack caused by loose knife holding screws .I have stripped down to the two castings and cutterblock ,having removed both grub screws and removed the collar on the end of the cutterblock drive side The cutterblock is holding both front and back castings together ,I only really need to remove the front casting but will give the cutterblock a good overhaul when out.
Anyone any ideas what might be holding it all together .I ought to mention this is the first time the machine has been stripped down since new 20 years ago!
DD
DD
