Inspector
Nyuck, Nyuck, Nyuck!
Big dog = secure.
FatmanG":2zlhw3a5 said:I have secured my shed with 2 bars of unistrut 41mm x 41mm withe brackets coach bolted through the concrete walls......
Inspector":2zlhw3a5 said:Big dog = secure.
MikeG.":2padc24o said:FatmanG":2padc24o said:I have secured my shed with 2 bars of unistrut 41mm x 41mm withe brackets coach bolted through the concrete walls......
In addition to the anchors for tying the shed down I was going to add a couple more for hard locking points. Had a few moderately pricey bikes over the years so got a small collection of suitably tough gear to secure it with.Richard_C":34t1kvxl said:You could think about some secondary security. I know a couple of people near me who have bike sheds with a short steel post/hoop coming up through the floor, one is cemented into a hole in the ground the other has a big flat plate bolted under the floor so just the post sticks through - easy to fit when you are building it. Bikes get locked to it, the chain or cable never goes out with the bikes so it can be as heavy as you like. Doesn't stop break ins, but thieves likely to go elsewhere once they see it.
You could get a battery powered LED motion sensing light over the door, I have one round by the bins (I can't tell the blue bin from the black one when its dark), cost me less that £10 for a pair and the AA batteries last for ages. Then maybe add an old webcam or a hole that might be a webcam with an appropriate label, no need to wire it to anything. Nothing is 100% secure but your shed need to look more of a challenge than one down the road.
Funnily enough I'd considered internal shutters for the workshop but wrote it off due to insufficient internal space to swing them open. The windows as designed aren't big enough to gain entry as they're only 150mm tall, so it really is only the window shopping factor I'm concerned about. This is all reminding me that I also need to beef up my workshop security, so that'll be happening in fairly short order after building this.MikeG.":2oy1u6t6 said:Have an OSB internal shutter that hinges up out of the way when you need light. No-one can see in, and anyone smashing the window to get in will have to smash the OSB too.
This is a good idea. I've got privacy roller-blinds in my workshop but something simpler for the shed would be good. The blinds are great for maintaining the mystery if anyone peeks over the garden wall. They also reduce UV damage to stuff inside the shed and mean we're not looking at piles of junk (and lots of clamps hanging across windows) when looking out from the house.Richard_C":2oy1u6t6 said:You could use obscured or frosted glass, or for less money stick frosted grey vinyl to the inside, even the stuff you get to cover books will do if windows are small.
