So I'm in the process of planning my workshop build.
We have a terrible garage - one of the old concrete prefabs with asbestos roof. It has holes everywhere and the wood (where it has it) is rotting
First step is to fix up the rotten soffits and window frames, which is all well and good, then we're rendering the thing for attractiveness (and somewhat sealing)
But one job I'm not sure how to tackle is the garage door
We've lived here 3 years now and I havent had the door open once, and I can't see me ever needing to (I don't actually have the key!) but I've been storing my lumber on a table in front of it for now. I'd like to actually board the inside of it and add some french cleat storage on that wall
The main issue I have is that the garage door has a huge threshold underneath that lets in water when it rains heavily... it also has gaps at the top since it was fitted poorly orginally... so looking for some thoughts/advice on sealing it up
Current thought is to run an angled plinth at the bottom on the outside, attached to the door to divert water, silicone from the inside to block as best as possible, then run a dpm across the wall before sticking some OSB in front attached to some vertical beams.
But, it feels a bit bodgey, so very open to other thoughts!
Thanks!
Thanks!
