Scrub plane choice
No skills
6 Feb 2011
Hanging by my fingertips
Hi folks,
I fancy getting an old plane and setting it up as a scrub, are there any rough guidelines as to what size is preferable? or does it not really matter?
I see a fair few cheap #4's on evilbay at the moment, would one of those do?
Ta!
Hey,
I set up a cheap GTL no.4 as a scrub just to see if it would work. I ground a radius on the blade using a roll of tape as a template. I also opened up the mouth of the plane with a file. this allows the much bigger chippings to move through. make sure the rear handle is good and strong or you might bust it.
Generally I think a longer sole is ideal for a scrub, but it depends a bit on what scale you are working on. I tend to use mine on panels and particularly those that don't fit the planer. Personally I would go for something in the range No5 / No6. And I would like to recommend an old woodie for the job. They can be found easily at bargain prices (£5 ebay, shift the decimal left for boot fair :shock: ). They are very easy to set up with a big camber, and light to use which is a real bonus when working a larger area.
I have a Record 6 set up as a 'semi-scrub' (a fair camber) and that works very well too... I think that one cost me over 30 quid though, ouch!
And before someone says an old woodie will be trouble, tired etc... just look for a clean one, decent ebay pics, no split in body where wedge goes, no big repairs etc. I think the vast majority are in fine form, and most have been in boxes for years anyway. Outstanding planes for so little investment.
Hi,
Wait untill Aldi/Lidl have a woodie smoother for sale again and camber the blade.
I picked one up a couple of weeks after they where on sale for a reduced price.
cambournepete":3upxdwui said:
My Veritas scrub is roughly the same size as my number 4 plane for the purposes of comparison
A "normal" #4 doesn't quite have enough space between the tote and the frog for vigorous scrubbing IME. I would recommend a #5, if you feel you must start with a Bailey.
My actually recommendation would be to either make one (Krenov style) or convert a wooden jack plane (or just USE a wooden jack plane with a little more camber than usual).
Personally, I converted:
http://web.archive.org/web/200901141057 ... scrub.html
BugBear
I use a scrub:
...from Dieter Schmid which has a very narrow, but deeply cambered blade. I wasn't sure I'd use it tbh, but it's the first port of call to remove all the crud from the surface of a board before the p/t - Rob
Some years ago I got hold of a Stanley 4 1/2 opened the mouth and ground a heavy camber on the iron. Possibly because of the weight of the plane and the width of the iron it worked beautifully. Unfortunately I lent it to somebody and never got it back.
Hello,
A traditional wooden scrub plane is about 250 mm long. The metal bodied varieties held to this same size. A no.4 or any other wide bladed plane would be a bad choice for a scrub, as the wide blade requires very high force to initiate a cut (not to mention the wide marks left behind the blade). Scrub planes have narrow blades: 30~38 mm is standard. Such a narrow blade can take a very deep cut (especially in straight grained softwoods, like deal), requires less force to push it through, and leaves narrow marks behind. My scrub is a traditional German pattern horned one, not dissimilar to Rob's ECE, but much cheaper. :wink: French ones are (generally) "unhorned".
Have a nice day,
János
I use a crappy pressed steel draper "plane" with a cambered blade, the mouth is big enough to drive my pick up through but it's small, light and easy to use.
Is the width of the blade really an issue when it is steeply cambered? The way I understand it the width of the blade actually in use is proportional to the depth of cut (and the degree of camber).
To expand on that slightly, a wider plane would be pointless (but not unusable) as the full width of the cambered blade could only be used for impossibly deep cuts.
Evening all,
Good info so far, thanks!
I'll round up my thoughts so far... (shouldnt take long :D )
Number 4 (or same sized other) could be used, and is by some - but others prefer something a bit longer.
Scrub irons are very narrow.
Hadnt considered a wooden one tbh, I think the currently available storage area wouldnt suit one either.
Almost any brand or type could be used, but I think I'd like something that would have a fairly durable iron * so probably rule out the el cheapo brands.
If I buy a plane with a fairly wide iron is there any reason I cant just narrow it then camber it for the prefered narrow size?
For anybody interested I was looking on ebay for wooden planes and found a little collection for sale in essex for not a lot of money, collection only tho.
* quite probably a side effect of being on here too much #-o
Yes Jim, many thanks and what a brilliant little plane:
A small Sorby scrub, 6" long, blade 1 1/2" width
It's in amazing condition and is a real treat to use. Ideal I think for smaller boards and I will use it when the opportunity arises to create a scrubbed finish on a panel underside say. Whilst a scrub is for first stage preparation, why not use it as a finishing tool - quite like using an adze to surface an exposed oak beam... very 'hand-made'.
In your debt again, Jim =D>
    39.7 KB
    40.8 KB
You are quite correct - the two planes I have used in this regard are "normal" woodies, with 2" and over blades, but they do indeed take narrow shavings due to the combination of depth setting and camber.
I suspect that a minor side benefit of this is excellent shaving clearance, since the shaving is nowhere near the arms of the wedge, precluding any possibility of jamming.
BugBear
Totally agree BB - I think a woodie jack for a fiver makes an outstanding scrub, and a very good starting point. The ECE of Rob's is probably excellent too and not silly at 60 euros - but those old woodie jacks usually have really thick irons which is a real benefit on a scrub (just set the cap further back to allow for the big camber, the iron is stiff enough anyway). Another thing about the woodies is their light weight - so your effort is going into the cut rather than shifting a mass of metal around.
Ah...yes...she is a beauty indeed...but there is another hundred or so bootfairs left this year so I shall be on the lookout for similar sized planes..or..if needs must I fancy making one out of beech and lignum vitae...perhaps this will be the first of a number of sliding dovetail designs! :wink:
The key is getting the iron...that is a wonderful piece of steel and the tapered ones are easy to come by...though perhaps less so in that size and age.
I think a photo of the scalloping would be nice with that width plane...I think that is part of the beauty of it...if you get around to it mate. I am 100% with you on the use of these planes to figure the wood...on old oak that would be a wonderful feature...an oak blanket box perhaps? 8)
Jim
Nice little plane, those and the wooden molding planes would end up being a collection or two quite easily 8) luckly I have nowhere suitable to keep them and no money to 'invest' in any :)
Still the tool budget is set for the month and the task is at hand...
(hammer)
Is that single or double iron? Who did the conversion (cambering of the iron)?
BugBear
