Adam W.
A Major Clanger
I have a Gransfors small carpenters axe with a very straight and thin edge, more like a very wide chisel.
I think this kindling axe is designed more for the lay-man, wide blade so easier to hit the target
They're spelt different.What's the difference between an axe and a hatchet?
I never thought I'd find myself admiring another man's chopperMy "joiners" axe here. Spear & Jackson. Weighs about 1.5 lbs. Not sure what the 1/4 stands for.
Official MSC issue about 1982.
Sharpened freehand on coarse side of a Norton No. "0" oil stone. There's a bit of a knack to sharpening but once you've got it it's easy. Ends up with a deeply hollowed stone, which is no problem.
View attachment 122515View attachment 122516
Probably look a lot nicer if you get a scribe as near as you can and leave it at that. Filler more likely to highlight probs than hide them. Depends on the details.Following this thread, would you then fill any gaps where the wood doesnt fit snuggly - and what type of filler would you use?
Not quite the same thing though - which you'd know if you stopped to think - in that case all the discrepancies will be hidden by the plaster as it's run up to the work. I sense that in the current case the whole face of the scribe will be visible. And I think it's been dealt with above how to deal with it. You scribe from the stonework in the plane of where the outer face of the work is going to be, and cut that as precisely as you can, then undercut behind that plane as appropriate.I used it most often for scribing inside linings of sash windows during restoration work - they need to be a good fit for plastering.
That doesn't relate to the current enquiry - you're spouting off.Extremely useful when you are erecting a green oak frame
What on earth has a block plane to do with scribing to stonework?then a block plane etc.
It is the same thing but not covered by plaster, as I describe above.Not quite the same thing though - which you'd know if you stopped to think - in that case all the discrepancies will be hidden by the plaster as it's run up to the work. I sense that in the current case the whole face of the scribe will be visible. And I think it's been dealt with above how to deal with it. You scribe from the stonework in the plane of where the outer face of the work is going to be, and cut that as precisely as you can, then undercut behind that plane as appropriate.
What tools you use are up to you - it's only the result that counts.
Quite handy following on from the axe. Use it with the workpiece on a saw stool with your knee on it and use the plane down across the edge. Just one of those things you might discover if you do enough site work.What on earth has a block plane to do with scribing?
I am deeply sorry and apologise profusely. I have not been called a spout before but shall quickly turn myself off as offending people like you is heart wrenching. The thread had turned in a axe direction as OP had solved his problem but I am mortified that I had not understood that you wanted to keep talking about scribing. It should be forbidden to deviate even slightly from the original topic. But thank you for your expertise and constructive contribution. Oh yes.That doesn't relate to the current enquiry - you're spouting off.
Good for the highs - not much use in the hollows ... ps I could do without the news about your knees :-(. Or your stools :-(((.Quite handy following on from the axe. Use it with the workpiece on a saw stool with your knee on it and use the plane down across the edge. Just one of those things you might discover if you do enough site work.
Had he? I missed that. :-(OP had solved his problem
There's a first, then!I have not been called a spout before
Yes. Well spotted. Congratulations.Good for the highs - not much use in the hollows ... ;-)
Of course! That's the default, isn't it?A cambered blade helps.
