Lancashire Wood Studio
I love this idea and you've done a marvelous job.
Thanks!I love this idea and you've done a marvelous job.
This is actually something I did a few months ago (birthday present for my wife). It's a scrabble table---as long as you're enough of a hard core scrabble nut to be happy with the power squares being colour-coded (pink, red, lt blue, dk blue). It's made from walnut solids: I cut up a slab and acclimatised it to indoor conditions while gradually handplaning it down to final size. So far, no warping! The letters are held in place by 3mm dowels cut from bog oak and sycamore, with the lighter wood showing the power squares: super fiddly to cut. The big curved leg is offset to allow you to slide the table under a sofa. It's made from a sustainable hardwood called ipe, comonly used for hardwood decking. I ripped it into strips with 6degree bevelled sides, glued it, and blackened it by fuming with ammonia ...
View attachment 100432View attachment 100429View attachment 100430View attachment 100431
Thanks for kind words! Yes, leather stuff is commercially viable (in a way that wood work isn't), I'm thinking about it .......Well I have to say that some of the stitching is absolutely carp! LOL!
You are a very clever and ingenious man, with great ideas and artistry.
The leather Travel Tabble ought to be sold as a design, you would definitely make money - how about Dragons Den? You'd easily get the backing to have them professionally made with a worldwide market. You could be a very rich man.
Well done, some magnificent work. Wish I had half your talent and a tenth of you idea skills!
I'm probably an interloper now though on this forum, so this may be my last post ....
Beautiful work and craftsmanshipOK, OK, I am a *bit* of a scrabble nut, and scrabble boards are rather a recurring theme. Unfortunately after a third major back operation, two of them in the last 2y, my surgeon has forbidden me from woodwork; but has eventually agreed that leatherwork is ok (easier to avoid stooping, no handplaning, lighter weight workpieces). So I'm now playing around with 3mm+ aniline dyed vegetable tanned hides, and of course my first project had to be a variation on my Scrabble Tabbles .... I'm calling it a Travel Tabble! I'm probably an interloper now though on this forum, so this may be my last post ....
Photos below.
1) I hope it's obvious, but in case not, the "handbag" in the first photo is actually the board wrapped around the cylindrical bag (for tiles and racks).
2) The dowels are 3.2mm shank flathead solid rivets, copper and aluminium.
3) Some of the dowels are slightly longer than others; the idea was that these in particular would engage with holes in the cylindrical bag so it was locked in place in handbag mode; but it's actually quite fiddly, more thought required.....
4) The red/navy/pink/light blue circles are 1mm calf, glued with PVA into recesses skived out of the leather with a router; this is a very woodwork-ish way of proceeding, I have some more "leathery" ideas for next time ...
5) The red and navy calf I bought, along with some undyed; I then used dilute dye for the pink and light blue circles
6) I've incorporated 5mm hemp rope into the handles (just locked in place inside by stitching)
7) Stitching the two sheets of hide (front and back) together was done by hand with an rhombus awl and sailmakers needles. I put a lot of effort into ensuring that when open the main board is flat, with the handles slightly raised, but it has the flex to wrap round in handbag mode. This is partly about how the handles are stitched, partly by varying the tension a little bit on the big circular line of stitching (which was done in 4 sections).
8) The cylindrical bag is lined with blue pigskin(the closing tab though is lined with brown morocco, I thought pigskin would be too fragile ....
View attachment 174256View attachment 174257View attachment 174259View attachment 174260View attachment 174261
