Phill05
Now if I could just persuade you to come round and give a practical demonstration....
Thanks Jacob!
Really that's far and away beyond my comfort zone. I'll leave that to the experts.
You should use molding / foundry sand to cast into as the heat hardens the mold/sand to reuse it, builders sand will loosen when dry, these are some old style sash weights I used to make, the mold box was made in two parts so I could put the wire hook wrap in the middle of the weight block they were made 20" long by 2" by 1 1/2" with a hook at each end so I could cut different lengths out to suite what the window needed, in the image you can see the parting line of the box in the lead, also you can see how the hook was placed.
In this second image these rounds I made to use on the bench for holding down timber whilst using the plane or holding down glued items.
I still use different sash weights as test weights on longcase clocks.
