You get into the handed habit after a while and see things in pairs mirroring each other. Clear face and edge marks essential - 2B pencil - big marks so that you can still see traces of it even after you've planed off mouldings and rebates etc.Ok, time to take a break. I realised I put the sash rebate and moulding on the wrong side of one of the jambs. So in effect I have 2 right jambs. It was going so well. Something had to go wrong.
The trouble, from what I can garner, is that you are working from a book which describes one method and then listening to the noise on this thread and trying to incorporate that into the process too. It won't work.Its “Door-making and Window Making” by Anon, circa 1910.
The reason I chose it was that it had a step by step method, which for an inexperienced weekend hobbyist like me, trying to make his first window, seemed like it might help me get to the goal. The other texts, Ellis, Cassell’s etc don’t really have the same “step 1, do this. Step 2, do that” approach, rather they are reference texts.
The content actually came from some booklets found at the bottom of Richard Arnold’s grandfathers tool chest, according to the foreword. Richard liked it and passed it on to Lost Art press and they published it.
The author actually describes 2 different variations, one simple casement with bevels followed by a more complex version with mouldings.
Then he goes on to box sashes, Venetian windows and bay windows.
I didn't pick up on this at the time, I have a book from 1980 by Sterling publishing which seems to me to be exactly the same content and title.Its “Door-making and Window Making” by Anon, circa 1910.
Yes, but not as you would like:Does the book describe the rod? If not there is a serious omission.
Yes but it works for a casements too. Good idea to get your hand in on a simpler casement.he's making a casement not a sash. that particular book has a really good explanation of marking up and how components the same length are marked together. the drawbore joint he's referring to is in the corner of the frame. so wedges are essentially useless.
Yes, but I took the measurements from a real window on my shed, thinking I might possibly install it. The existing windows aren’t high quality or attractive. But they are 1) Hardwood 2) stormproof 3) slimline double closed 4) draughtproof so me installing mine just “because I made it” doesn’t seem like a great idea really.Do I get the impression that this is a practice piece Steve ?
If so trim the jambs length to remove issue and recut the joints.
I don't need to say reduce the height of the layout board to match, do I ?
Cheers, Andy
For your sanity, I would advise working through the method in that book, which is sound, and ignoring all the other inputs which you receive on this thread. Once you have done that find, another source and work through that until you have made the window, then you will be equipped to tackle any method which you have found or adapted that works for you.
As for the drawboring on sash windows ditch it, because the pin holes are bored once the sash is assembled and wedged, then finally pinned with straight cut pins. This is a belt and braces system which includes a fail safe should the wedges fall out.
Oddly, the early books (Moxon, Nicholson etc) were written more for the gentry than the tradesmen - who let's face it were most likely utterly illiterate. They'd learn the "traditional" way i.e. skill passed on from person to person from a huge body of accumulated traditional knowledge not actually written down anywhere, but often highly sophisticated.....
The reason is I was struggling to interpret the text, which is very “Victorian” … the author may have been a great joiner, but a terrible communicator and it is full of ambiguity and scant detail. ...
I am more than aware as to what a rod is and how to use it, for example:Those aren't "rods" in the trad sense.
You'd need a "rod" anyway i.e. full size drawing, to be able to extract the marks you need for your measuring sticks.
With the rod system you mark up direct from the full size drawing and don't need the extra process of marking up measuring sticks, and you avoid the random errors this could generate.
And the rod (on a board) follows the work around the shop, so singing from the same sheet at every point.
Oh! My bad. Thy are dovetailed here, but that's a whole different thing and best not started on.he's making a casement not a sash. that particular book has a really good explanation of marking up and how components the same length are marked together. the drawbore joint he's referring to is in the corner of the frame. so wedges are essentially useless.
