Sanding + grinding replacement belt advice
20 Jul 2015
Rochford, Essex
Hi,
I've had a Clarke CBG6SB 150mm Bench Grinder with 50mm Sanding Belt for years.
I don't recal ever changing the belt and it is rather worn. The way I abuse it, I'm amazed it hasn't snapped. I sand wood, ferrous metals, non-ferrous metals and plastics. I don't have to press very hard before the little 250W motor stalls.
I'd love a proper linisher, but I don't have the required £500 (GBP) to $5000 (USD) required.
I read (on here - I think) about diamond belts and searching for that post, I've discovered ceramic and zirconia/zirconium? too. I've also read that some of the wonder-belts need powerful and fast machines. My hope is that one of these wonder-belts might improve the machine's performace. I think I read that the ceramic belts require the user to wear all sorts of PPE. Maybe I'd be wasting my money and might as well stick with a half-decent aliminium oxide belt.
If anyone has any thoughts or advice they'd be willing to share, I'd be very grateful.
Many thanks.
W.
    396.7 KB
Ceramic belts need speed and pressure to cut well so I don’t think you’d get the benefit on your machine.
I think the most benefit you’d get is buying a few new belts so you can regularly replace and have a fresh one for non metals, and a slightly used one for metals. Alox would be fine.
The need for ppe is due to
- grit and whatever you’re grinding getting in your eyes- no fun having metal shards pulled out of eyeballs.
- only having one pair of lungs and breathing dust being a bad idea -grinding grit being inert so once it’s in them it doesn’t come out easily
- anything loose by anything spinny being a bad idea -some people wear gloves when grinding it gives me the heebie jeebies
My belt sander takes a 1”x42” belt. I use the zirconium (blue) belts from 40 grit to 320 grit for grinding metal. I have various other belts for knife sharpening (up to about 1000 grit) and a leather belt for honing.
Write your reply...
