tekno.mage":2u5h7el0 said:
Sadly, many modern consumers seem more interested in the fashionable look of a "designer" item than it's durability :-(
Sorry, rant over.
You're quite right.
At the time we installed it, I looked for a long while for something to fit in the space. The whole room is _very_ carefully worked out to fit everything in the space, and that toilet bowl has to be exactly where it is, otherwise we couldn't have a loo in there at all. It's so tight that one side of the cistern is against the glass panel of the shower screen (this looks better than it sounds!).
I was disappointed when I ordered one with a syphon (or so I thought), and received one with a bloomin' EU flap-valve. Yup, that now leaks, as does the other one in the house. It's stupidly complex and requires a complete replacement valve assembly, apparently. Syphons, in contrast, CANNOT leak if set up correctly, and the piston flap is pennies, literally (you can make them from the side of a 3litre milk container!).
I took a cursory look at the seat and thought it would be strong enough. It wasn't till it failed that I realised it was, in effect, spot-welded together - in one spot, across a 10mm metal 'mortice and tenon' joint in 2mm stainless (might be even thinner)!
I so wish we had First Amendment rights in this country. There should be a web site where product faults can be listed, by product and by manufacturer, so that the bad ones can be exposed. They could be ranked by 'propensity to rip-off'. I have my own list... :evil:
E.
PS: The few remaining examples of Victorian and Edwardian plumbing still work. Why does the modern stuff fail after a few years?
