Phil Pascoe
That's one small dehumidifier. Mine's a small one and it's 250w.
Honestly it works really well, I live about a mile from the coast so really humid and really salty air! Plus I’m in a small shed workshop.with no insulation so get the swings of humidity and temperature. I run it year round, depending on the weather have to empty it maybe once every 2-4 days.Optimal working conditions 30c, 80° humidity. Probaly counts it out for sunny Cornwall - never that warm and rarely that dry. How well does it work?
I have taken to this too. I run a biggish DH for a couple of hours each evening on a timer aiming for 60% RH. On damp days it knocks a lot of water out of the air. 3L of condensation every few days is quite a weight and more than enough to keep the houseplants watered.That's one small dehumidifier. Mine's a small one and it's 250w.
Liquid paraffin from your pharmacy is what you need to thin itHello Sideways,
Thanks for your reply.
Addendum: mine is not "water-thin". It is more like a light cooking oil. It certainly has some body to it.***
If memory serves, I purchased a small spray bottle of Camellia Oil from one of the larger woodworking tool outlets years ago that was made in Japan. I did not use it on an "oil can" at the time. In retrospect, I do not recall having the same gumming issues with that small bottle.
My current bottle of camellia oil was purchased on Amazon: "Dr Joe Lab Camellia Seed Oil is 100% Natural Pure Cold-Pressed Japanese Camellia Seed Oil Grade A". They fail to specify where it is made... China, I suspect. ***Perhaps I have purchased an adulterated product?
How does one prevent the oil from gumming-up on the cloth of the oil can, where it must be applied liberally?
I am thinking of experimenting with a dilution of 50% Camellia Oil and 50% paint thinner.
Make your own - it's way cheaper. here's one, it would make a lifetime's supply.I've always used Renaissance wax .
https://www.preservationequipment.com/Catalogue/Cleaning-Products/Cleaning-Agents/Renaissance-Wax
Is "Liquid Paraffin" the same product as conventional "Mineral Oil"?Liquid paraffin from your pharmacy is what you need to thin it
Hello Phil,Make your own - it's way cheaper. here's one, it would make a lifetime's supply.
Hello Isaac,I use Camellia oil, its definitely thinner than, say, warm olive oil (not that I'm particularly familiar with the properties of warm olive oil, but a friend told me!). I wipe it on and then off and then in the autumn/winter/spring follow with a coat of liquid wax (also wiped off).
I have never seen the gummy effect you describe.
Camellia oil is quite expensive and you say you have a huge bottle. How much did you pay for it? Is it possible that it's actually another oil with Camellia added and then sold as "Camellia Oil"?
Yes, likely it is an older bottle of oil. There was no expiration date on it. Amazon has oft been criticized for selling outdated products... one of the reasons they are sometimes cheaper. "Unlucky" is perhaps not the correct term...I use this product: https://www.axminstertools.com/came...0018?queryID=160ae1ebf0f7721c71274d27c0ea01c2
Which works out about twice as expensive. That's not beyond the bounds of possibility given that buying larger quantities often gives a discount. However, I have no facilities to test the claim that the product is 100% pure Camellia oil.
However, Camellia oil will polymerise over time. Maybe you have been unlucky and have been sold old product which has started to polymerise?
