studders":3ny85hic said:Looks good to me though the 'shoulder in the ring' bit has confoosed me. What's it for? :duno:
RussianRouter":33qltfyy said:studders":33qltfyy said:Looks good to me though the 'shoulder in the ring' bit has confoosed me. What's it for? :duno:
Its also confussed me as well,looks like a ridge but it just might be the camera playing tricks?
studders":mjhaqg4z said:RussianRouter":mjhaqg4z said:studders":mjhaqg4z said:Looks good to me though the 'shoulder in the ring' bit has confoosed me. What's it for? :duno:
Nah, I'm talking about the proposed Plates RR, not the one in the photos.
Dibs-h":3agwa31k said:The shoulder is in the plate so that a 3mm (or whatever the ring is) won't stand proud.
Dibs-h":3agwa31k said:The only reason for mentioning whether some folk wanted a shoulder cutting in a ring is that they felt it would be good to use Porter Cable (or similar, perhaps Trend) bushes.
Dibs
Dibs-h":22pjkcrx said:... I will ask what the extra cost might be for laser marking - can't see it being much, especially as we aren't asking them to cut anything.
Dibs
Dibs-h":j4w18cb7 said:Update:Finally out of slackpuss mode and updated the drawings.
- altered the length slightly so it is 306x229
- guide pin is now 6.3mm as opposed to something else,
- discs\rings are on there as well.
Folks happy with the above? I'm 1/2 terming this week till Friday, when I'm back at work. Will be emailing several laser\water cutters on Friday based on nominal nbrs and should hopefully have something back for Mon\Tue next week.
There were folk that wanted a shoulder putting in a ring\disc - what dia hole should be in that ring? And the dia and depth of the shoulder? If this is a goer - then it would be 2 step thing - get this ring cut as per the rest (assuming it isn't just one or 2), then get the shoulder cut when the shoulder for the plate gets done.
Sorry for the slackness.
Dibs
