As I have said to others considering the Incra system. If you want a router table to do joinery, dovetails, finger joints etc and repeat set ups then as long as you have the space (the equivalent of 3 router tables deep) the Incra is brilliant. It also does all the normal fence based stuff. If you do not want to do those things then a normal fence solution is sufficient. Although I note the Jessem is more than the Incra Wow! You pay for great quality though. Both are a long way from a hole in piece of ply 2 G clamps and a length of 4x2 hing off my workmate (my first router table).
