Looks a great table. I have a triton tra001 under my router table, and thought i would pass a couple of bits of info i have picked up using mine. First, you may find the cover over the switch won't close after use. Normally this is fixed by lowering the router first till its clicks then raising it to change bits. The collet won't lock without it closed so you will need to do this.
Also related to this, the tra001 is known for dust getting around the switch especially when using mdf. I have a decent dust extraction system, but have had to remove a couple of screws to clear out dust which was stopping the collet from locking.
Other than that, the router is a beast, i use mostly oak and it works a treat and is easy to use.
Sorry if you already know this, but as i took a while finding out, thought it worth passing on.
Nick
