MatthewRedStars
If you imagine that the bevel on the long grain rotates from being square (90 deg) to 45 deg and onwards towards being as flat to the panel as possible (the panel becomes infinitely thin).... then it seems correct that the "potential breakout tendency" becomes exponentially more favorable against a linear "angle-to-breakout" ratio as you increase the angle of the bevel.
This is hard to explain in words but a long grain bevel will reduce breakout when planing end grain. The bigger the angle the better as the panel becomes "thinner" and the planing angle when the blade exits the work becomes closer to parallel with the planing direction.
