Max Mancino
Learning curve of a spokeshave is not as steep as I imagined. Give it a go and I am sure you will realise you didn't waist your money/time. In addition, there is a lot of fun and sense of accomplishment after you realise that it was not that difficult. Of course you will not get surgically precise results... but, at the end of the day, even thought I am a perfectionist myself, I found out that it is by far good enough. Cheers,Will a spokeshave create a 1.5mm precise/accurate/clean arris/chamfer on a curved workpiece? If it can, and I'll learn something from it, then I'm more than happy to give it a go. That's what it's all about at the end of the day, BUT I have (obvious) doubts a spokeshave can achieve this without a huge learning curve to achieve acceptable results, and even then I'm doubtful on the accuracy of the cut.
Max.
