a copy of forum reply.
You can run a copy of BIAB like that, but not a copy of PT. PT should be installed from its .exe installer and then upgraded with patch. If BIAB is all you want, you are likely good to go, but I'd include an extra copy of the .exe install file for BIAB plus the upgrade patch file on that disk, too, just to be safe. Doesn't take up that much space on today's drives. I'd make sure I included the install files for the VSC and VSC DXi on there, too. Installing to the new laptop's C: drive using the installers is always a good idea, especially considering the installation of DX effects that come with the programs, they must write to the registry
I do not understand the PT (power tracks midi software) and BIAB re its .exe installer what that instruction means?
