Repairing & Levelling Concrete Floor In New Workshop
Delaney
4 Jul 2023
Hampshire
Hi all.
I have moved into a new workshop and the concrete floor is all over the place. I would like to take out the slope and make it flat.
I've spoken to several screed contractors and several concrete contractors, not to mention suppliers of both materials and the variation in opinion is large.
I have several machines that are 600-700 kilos in weight so the surface needs to be strong.
I have been told by concrete layers and suppliers to stay away from screeds like sand and cement as they will not be strong enough.
I have been told if I lay cement, C30, the minium thickness needs to be anywhere from 150mm to 75mm. That I would need to include mesh to stop cracking and
will take a week plus to dry. This seems unpractical.
Liquid Screed types tell me that I can lay a liquid cement that can be put down to bonded cement as thin as 30mm and go up to a thickness of 300mm (on some products ‘silka’). This is more suitable due to there being a slope of roughly 150mm across the floor from one side to the other.
My concern is that if I lay a liquid concrete, it won't be strong enough, although 'FlowCon’ is rated at 55 newtons, is C40, min depth 30mm and for 7 m3 would cost £2000+ VAT.
Looking for advice and or experience with this type of work. Just don't want to lay something that won’t work.
The existing concrete it stable, its just a farm so the unit was a chicken shed and the concrete not poured for flatness.
Someone has already tried to lay some self levelling, which is cracking and not level at all.
Here is the existing floor.
    11.8 MB
Much of the success from whatever you choose will depend on its interaction with what is there already.
That means the sounder the existing, the cleaner the existing, the more dust-free the existing, the more keyed the existing is, the better the new will bond to it.
The contractor laying it will not care - they will pour onto whatever is there the day they arrive. Hence, you have to assume responsibility for the preparation work. That could be as minimal as a good jetwash but could extend to repairing any dodgy parts and keying the surface with one of these:
https://www.wh-surfacepreparation.co.uk/f20-hire-200mm-floor-scabbler-spe-bef200-electric/6
Another great influence on the success is how the material is cured after laying. The contractor will do nothing at all on that front. Again, you can take responsibility for that. Sodium silicate solution is a great curing and dustproofing chemical and is cheap. The challenge with spraying it is how you reach the entire area of the floor. The first spray needs doing on the day the material is laid, after it has gelled over. That might mean overtime for you if the laying does not finish until 1600h.
You should not expect to use the floor the day after it is laid. Spray again as early as possible the next morning and cover with plastic sheet to keep it moist. On the second day after pouring, it would probably be OK for light use.
If that was just a chicken she'd, there's no telling what sort and quality of base it's both on and made of.
It may benefit you to dig a few test holes spread out about the floor, to a depth of about 300mm. Just to check you are working from a good start point.
It would be a disaster to spend a few grand, only for it to fail quickly, because the sub base collapses on you.
Would an epoxy screed not be suitable? The maintenance crew in a factory I once worked at , used it under all the heavy duty machines that they installed.
If you have any doubts concerning the strength of floor slab try contacting someone local that can provide results from a Schmidt Hammer test.
I can only say that the concrete floor that is there, is part of a huge concrete slab, that contains at least 300 m2 + of units.
Mine is in the corner and so the concrete slopes off.
I have to bare in mind that it’s not my workshop and it is cheap but the floor as it is, is very uncomfortable to stand on for any amount of time.
I had thought about hiring a concrete grinder to at least try to remove the smoothing compound laid incorrectly by the previous tenant and take out some undulation in the concrete base.
The concrete base that is there is not new and if a new surface is applied and cracks, that would likely still be far better than what is there, unless we’re talking about complete failure, which surely would mean the concrete sub floor is on the move, which I doubt it is, after all this time.
Or are you implying that the weight of the screed, could cause issues with the ckncrete?
My workshop is inside an old barn with a deliberately sloping floor.
The previous guy who had it basically just built a complete insulated building inside the barn starting with levelling the floor, there is about a 400mm step at the front. Just joists and chipboard t and g, I have some heavy stuff in there and it is fine ( getting it in and out not so much ).
You could do similar, just ingnore the concrete and its lack of level by building a nice new level floor on top handily skipping over all the lumps and bumps.
Might be cheaper than concrete and you can insulate under it.
I was thinking more that the existing floor was maybe not designed to take point loads in the 600 to 700kg weight range.
Coming at the problem from a slightly different angle...
If you know where you want the heavy machines to be positioned, can you not make wooden forms and cast new, level, concrete pads (inc. mesh) in place? If they need to be tied into the existing floor you could run concrete bolts or resin fixings into the existing floor, leaving a couple of inches proud of the floor, so that the new concrete flows around them and they lock the new pad in place.
Once you allow them to cure and (forklift?) the machines into place, you could then level the rest of floor, working around the concrete pads, with screed and then cover it with whatever you like as cushioning/insulation.
Yes I agree with @Ollie78, it’s what I’ve done twice in the past, 2x4’s on 16” centres packed up with a waterproof layer on the concrete first, gives a level frame to put insulation inside then 18mm OSB T&g on top, I gave mine 3 coats of water based poly floor varnish and even with sliding my cast iron lumps around it has survived virtually unmarked for years, and much more pleasant to stand on and work in.
I’m just about to do it all again in my new space over here.
Ian
Ian
Hi Ian, can you expand on “3 coats of water based poly floor varnish” please, I’m intrigued about the actual product as it might be useful for a project I’m working on. Thanks
I converted a horticultural packing shed to a workshop. I laid 1" jablite sheets (polystyrene) and then a T&G chipboard floor glued at the joints but "floating". I had a large three phase panel saw and various other large machines. Any machine's weight is spread out over an area so it is not a point load. The floor was still fine when I demolshed the building 10 years later. As you say it is not your building so keep costs down as much as possible. At the door way (double doors) I concreted a parking area so a vehicle could be loaded/unloaded inside, again still fine when I demolished.
That is all well and good, but you may need to discuss how this could be done an a floor that "is all over the place" and one on which the OP "would like to take out the slope and make it flat".
Start, for example, by detailing how you cut accurate cheese wedges of polystyrene.
No need to cut cheese wedges of polystyrene.
A layer of sharp sand can be used to level the surface before the insulation layer is put down.
Hi Jon, I’ve always been impressed with and for years have used Johnstones water based poly varnish on nearly everything I’ve produced, they do another version that has an even tougher finish designed for floors. I actually only did the third coat on the heavy traffic areas to save time.
Fairly readily available.
Ian
Hi all
Had a screed contractor come round today and he seemed very confident that the floor can be addressed in several ways but one that he and the owner liked, was pouring some liquid screed (anhydrite) around the high area to build up the outer edges of the room. He seemed happy that that would stick to the existing screed already poured (badly). Then once set he can go over the whole floor at a min of 30mm.
He seemed very confident that what was there did not pose an issue and would take the weight of the machines.
I mentioned that what has been poured already, was not sticking down to the cement base very wwell but he said it wasn't going anywhere and he wasn't concerned by it.
Honestly it all seemed a bit too easy, compared to what I've been reading online and from what I've gleamed calling over 4 contractors, 2 suppliers and other relates sources (including here).
The guy who came round to do the quote is a nice enough chap and I have no reason to doubt his ability.
I can’t find too much about his business, reviews etc.. but until I get another quote or two, it’s hard to say.
I suppose a couple of potential orange flags are:
1) He seems quite available. I don't know his industry but my experience tells me that the tradesman who is available the soonest, is the usually the one you want the least. The best people are almost always booked up a month or two in advance.
2) His van is badly beat up and without signage.
3) His website talks in plural ‘we' but it seems as though he is a one man band. This isn’t uncommon though and his website is actually vey good.
4) I could not find any reviews about his company but it has been registered since 2011.
But saying that, a very nice guy.
Here is his website.
https://www.flowscreedingservices.co.uk/
I don't want to be unfair but I can't tell if the photos used are stock photos or not. Some of them look like generic pics pulled from online. Also at the quote he initially gave, I cannot tell if he works with someone else or not. Certainly mixing that all up by yourself would be a mammoth task.
I’m getting ahead of myself. When he puts in a more formalised quote tomorrow, I’ll ask him some more q’s then.
Ask for some personal recommendations and previous client's you can talk too and go to see his work.
From his web site:
"we are recognised as a manufacturer-approved installer across the UK" Ask what manufacturer's has approved him as an installer? Then contact that manufacturer to verify.
He is probably a franchise from the company flow screed, maybe stuff that's there the liquid screed will seep under and stick it down maybe that's why he is not worried you may find he is salesman for main company. Good luck
Hi pip. Interesting.
The guy that came is def the installer.
I have used Flow Screed and have been very impressed with the results. 'Sticking' the screed to the base isn't an issue at all in normal use, as it is generally poured on top of a plastic sheet over insulation. The plastic needs to be sealed around all pipes or upstands and the sheet carried up the walls, as the liquid screed will go under the insulation and float it.
I would have no hesitation in using it in your situation. Indeed, I would even install a layer of hd insulation under it as a thermal break.
When you see it being laid it is difficult to see how an installer could get it wrong.
