Hi all.
I have moved into a new workshop and the concrete floor is all over the place. I would like to take out the slope and make it flat.
I've spoken to several screed contractors and several concrete contractors, not to mention suppliers of both materials and the variation in opinion is large.
I have several machines that are 600-700 kilos in weight so the surface needs to be strong.
I have been told by concrete layers and suppliers to stay away from screeds like sand and cement as they will not be strong enough.
I have been told if I lay cement, C30, the minium thickness needs to be anywhere from 150mm to 75mm. That I would need to include mesh to stop cracking and
will take a week plus to dry. This seems unpractical.
Liquid Screed types tell me that I can lay a liquid cement that can be put down to bonded cement as thin as 30mm and go up to a thickness of 300mm (on some products ‘silka’). This is more suitable due to there being a slope of roughly 150mm across the floor from one side to the other.
My concern is that if I lay a liquid concrete, it won't be strong enough, although 'FlowCon’ is rated at 55 newtons, is C40, min depth 30mm and for 7 m3 would cost £2000+ VAT.
Looking for advice and or experience with this type of work. Just don't want to lay something that won’t work.
The existing concrete it stable, its just a farm so the unit was a chicken shed and the concrete not poured for flatness.
Someone has already tried to lay some self levelling, which is cracking and not level at all.
Here is the existing floor.
