bugbear
If only there were some standard measure of power, obtainable by multiplying current and voltage together...D_W":239iv7lo said:Very low power sander, less than 4 amps at 110v.
BugBear
bugbear":1pca9sny said:If only there were some standard measure of power, obtainable by multiplying current and voltage together...D_W":1pca9sny said:Very low power sander, less than 4 amps at 110v.![]()
BugBear
It's a UK forum Dave - do try to fit in!D_W":1onvyv8i said:bugbear":1onvyv8i said:If only there were some standard measure of power, obtainable by multiplying current and voltage together...D_W":1onvyv8i said:Very low power sander, less than 4 amps at 110v.![]()
BugBear
We generally don't describe motors in watts here. Just the way it is.
Jacob":3aregvqs said:Why not use the belt sander for sharpening - then you wouldn't need to flatten the stones? In fact you could just bin them.
D_W":s7o7iase said:At any rate, do you guys do these tools over there (the combination belt disc sander) or are the little scabby homeowners versions like this something that they can only get over on americans?
essexalan":2ayiovv5 said:Never seen one used and have no use for one, here's a cheap one http://www.axminster.co.uk/powermatic-3 ... der-102216. No room for tea bags though but you can probably get a tray attachment for a tea pot plus a plate of scones. Real Englishmen use tea leaves not tea bags old boy and you put the cream on your scone before the jam.
essexalan":26daacjy said:Never seen one used and have no use for one, here's a cheap one http://www.axminster.co.uk/powermatic-3 ... der-102216. No room for tea bags though but you can probably get a tray attachment for a tea pot plus a plate of scones. Real Englishmen use tea leaves not tea bags old boy and you put the cream on your scone before the jam.
essexalan":2dx41fo8 said:Never seen one used and have no use for one, here's a cheap one http://www.axminster.co.uk/powermatic-3 ... der-102216. No room for tea bags though but you can probably get a tray attachment for a tea pot plus a plate of scones. Real Englishmen use tea leaves not tea bags old boy and you put the cream on your scone before the jam.
