merlin":yhm8j9oc said:
Just had a measure.
The face of the spindle casting / machining does look a bit half assed but won’t make any difference ( if that’s the part you mean?).see photo.
Yes, the machined bit the "hub" part of the riving knife assembly (still not sure what to call that thing) rides on. Mine looks like the intern did it with not much supervision. I'm hoping to get the saw out tomorrow to get the fence rail re-mounted after I got it cleaned up today, so I'll see if I can get re-acquainted with the guts of the machine.
The width from Spindle casting to circlip is 18mm.
From the circlip face to the linkage face is 6.4mm.
There aren’t any shims.
Hope it makes sense....
I *think* it makes sense... if you are talking about the spindle casting itself rather than the "hub" (again, the roundy bit of the riving knife assembly that rotates on the spindle casting itself).
Also if the circlip is the clip that rides in the groove in the spindle housing...?
Net, net If that "hub" rides on the spindle housing between the rear ridge (the beginning of the un-machined part of the spindle housing) and the spring clip with no for/aft movement then I think the only critical measurement I would need to re-create it would be from the face of the hub as it rides against the clip (in its groove) to the machined face that the links attach to... if you get my meaning...
I'll take some pictures and measurements tomorrow and then draw on the pictures as my spindle housing is easy to access and should keep you from having to take your saw down to bits to help me out!
Thanks again for the help!
KT
PS: Looking at your pictures again, it does look like that "hub" is mounted snug to that clip leading me to believe it isn't allowed to move (except in rotation as it should).... Which means, ignore the above as your measurements now make sense to me...
*there are, I believe, some very acceptable "colonials" jokes and or head shakings allowed in all this....*
