Having just picked one of these up at auction I have no clue how to use it properly. Luckily it came with a tatty box and instructions so I'll put them here in case someone needs them for reference in the future.
Check on ebay come up from time to time plus there is a seller 3D making them.I have one of these too, however I’m looking for a fence arm for it.
I'll have a rummage in my bits box: I'm pretty sure I've got one, and if so, you can have it for the cost of postageI have one of these too, however I’m looking for a fence arm for it.
Form the rebate slightly away from the line then take the last passes from the wall with the plane on its side, to take it back to the line and remove steps etc. It's quicker and easier than trying to cut both faces perfectly together.the 78 used to be very common - a great rebate plane. I find the most important part of using one (apart from starting the cut on the far end of the wood) is to make sure the vertical surface is always in full contact with the workpiece. once you get 'steps' on the vertical part of the rebate, it can be tricky
That`s very kind of you.I'll have a rummage in my bits box: I'm pretty sure I've got one, and if so, you can have it for the cost of postage
that approach can be problematic with tricky grain unless your rebate plane works on both sides. I try to get it right first time but usually use a shoulder plane to clean the vertical surfaceForm the rebate slightly away from the line then take the last passes from the wall with the plane on its side, to take it back to the line and remove steps etc. It's quicker and easier than trying to cut both faces perfectly together.
This is why the fence, nicker and depth stop are a bit redundant on the 78 and variants. They actually get in the way and it's easier to plane to gauge marks in the old fashioned way.
