Record Power AC 400 air filter mounting
themack
UKW Supporter
17 Mar 2023
Swansea
I have hung my Record Power AC 400 from the ceiling in my workshop last night. The ceiling is only 2.10 m high to comply with planning (it's a garden room). I managed to fix the hooks the right width, but in order to use the ceiling beam I had to have the hooks 7 cm further back than the actual hooks from the unit dictate, which is not a problem. I can walk underneath, but would like to hang it a bit higher. I could ditch the chain supplied ( which doesn't look very sturdy in the first place?) and try to hang it hook on hook or use the supplied ring as connector? Has anyone tried that? I am obviously looking for a safe way as I don't want the unit to end up on the floor, it weighs 14 kg after all 😬
I mounted mine against the ceiling - the pic shows the principle although the ceiling is now insulated and has plasterboard - the Record unit is flush against the ceiling with the "legs" hanging down and attached to a piece of 12mm OSB to form a thin platform (between the legs) - that maximises the under-height. The remote is stored on the edge of the platform (I'm about 6'3" so no problem to reach it)
    1.9 MB
I stood mine up vertically on a shelf - works great
Sadly I haven't got the space for a shelf anymore which would be in the right position.
Thanks for the picture, I might have to resort to that with mounting it via battens screwed directly to the ceiling.
How about a double sided horizontal French cleat, for want of a better description.
Mount the unit to a plate with angled edges. Fit two French cleats flat to the ceiling.
You can then slide the unit in and out for maintenance.
That's pretty much how I did it once the ceiling was boarded - battens attached to the joist at 90 degrees to fix the end of the legs.
This thread has reminded me that I need to relocate the filter as I've moved the woodwork machine area of my workshop (and the overhead space where it is now will store some of my bicycle related, infrequently used, tools)
In my last workshop which was in the basement I had mine mounted to the ceiling as you have described and there was no problem.
I have a small workshop and when I fitted the AC400 to my ceiling with the chains, it was obviously too low as I could bump my head on it. So I just hung it from the 4 hooks I had put into the ceiling.
No problems whatsoever.
Given some of the ideas mentioned before, if I had a larger workshop with a bit more ceiling height, then I might have tried the shelf on battens idea. But I have to live with what I have.
Hi all
thanks for all your suggestions. Gives me food for thought. I thought about just hanging them hook on hook, but the two hooks at the back are not aligned to the hooks above as the roof joists are not the width of the hooks, they are 7 cm further away.
