Recession Beating Bespoke Table!
joiner_sim
7 Jun 2007
Staffordshire
Customer had requested a bespoke table, the only requirements being a table top size of 24"x22" and as cheap as possible. The table top is 18mm MDF, the legs and underframe are 44x44mm PSE. No real wood work joints went into this. The underframe was screwed to the under side of the table top, allowing a gap in each corner for the legs to run up to. As you can see from the photo the legs were just screwed straight thru to the frame. Glue was used! :lol: Then just to seal it all after i gave it a quick rub down with sand paper and then 3 coats of clear varnish.
Nothing special but thought I'd post it anyway as its the first home-made item I have done in a year!
