The table still isn't finished, but here's a quick update with some pictures to show the sort of detail I have been playing about with.
I'm still undecided about the finish I shall use. Guided by Custard's experience it will probably be some water-based aniline dye with Osmo Poly-X on top, but I have various scraps around the place, with different options on them, gathering extra coats and waiting to dry. Too tedious to photograph, you'll be relieved to hear.
One thing I do know is that if I am going to use a water-based dye, it will raise the grain unless I raise it with plain water first, so I have done that. This is simply a question of wiping over with a rag moistened from the hot tap, letting it dry, then sanding over again - in my case, using 400 grit Abranet.
The table top has a pair of tiny insect holes, right in the middle. Now, I could have planed away the wood to remove them, but that would have made the top about ¾" narrower. I didn't want to do that and thought I could make them disappear. I'll soon find out if I can!
So here are my experiments on an offcut which has some similar holes.
Walnut stain and hide glue.
Stir in some walnut sawdust
Take one hole
Fill
Smooth
Then apply stain and oil and wait to see how it looks.
I also fiddled about with the fit of the drawers. In an attempt to minimise the space wasted below the bottom of the drawer I have left myself with very little clearance - a bare ⅛". So the little drawer stops needed trimming slightly. I could have done this with just a chisel
but it does justify buying one of those cheap but tiny Mujingfang planes - just the job in a tight space, as this clumsily posed shot attempts to show:
That's about it for now, while I wait for samples to dry and recover from the shock of this afternoon's earthquake.
