Buoyed up by my success with straightening the wonky drawer, I was pleased to see a day of dreary drizzle outside, so it was time to get back to the workshop.
First job was to clean up the cedar bottom. From this
through this
to this
was fairly straightforward. It's something less than ¼" thick. The exact thickness doesn't matter as I will make it fit later.
Before the bottom can go in place, the drawer needs to fit the frame. In one way, this is simple - you "just" plane away the surplus wood until it fits. This is the trad way to hold a drawer to work on it, and I don't know a better one.
There was a lot of that to do, and plenty of offering the drawer up to see if it would go in. Once it would go in, there was more planing to do, to get it to slide in easily. What makes it hard is that you can't easily be sure what the cause of any resistance is, at least, I can't. So you could be planing the edges of the drawer sides, reducing their height, when you ought to be planing their faces, reducing the drawer's width.
Anyhow, when it finally does this, it all feels worthwhile.
In my case, the time taken was about an hour, but that's ok, I quite like planing.
Here's a closer view, of the dovetails and the drawer in place, just to let me feel happy for a bit longer.
After a short break for lunch, it was time to get back to the bottom. I looked back at what I posted when I made my little chest of drawers, to remind myself how to do this, but it was a bit light on details, so I took more photos of this stage. I think this is the same as I did on the earlier project.
First step was to plane the front edge straight, line the drawer up with the bottom, and mark the overall size of the inside.
That's not the size the bottom will be, but the lines are where the outside edges of the slips will be. So I lined up a slip with the pencil line
rested a steel ruler up against the other side
and made a knife cut along it
This line will be the shoulder of a rebate. The overall depth of the rebate is ⅛", so I marked across ⅛" and cut another line.
This is the edge of the bottom, so the next step was to saw up to it
To mark the depth down for the rebate, I like to use this sharp-screw-in-a-block gauge, which is nice and positive for fiddly little things
To make the rebate I just split the wood off with a broad chisel
and trimmed it with a paring chisel and a little bullnose rebate plane
And here it is, fitted in to one of the slips.
I then repeated this on the other side.
The ends of the slips need little stub tenons, which fit into a groove on the back of the drawer front, like this
That may look a bit rough, as I find it hard to measure things at this scale, so I deliberately sawed oversize then pared back with a chisel until it fitted.
The front edge of the bottom needs a rebate on the other face, which lines up with the stub tenons on the slips and fits into the same groove on the drawer front. Again, I just marked a line and planed by eye and by offering up, until it fitted.
Then, having established that it would all fit, I sanded the insides of the drawers while it was easy to get at them and also the slips themselves. Then it was out with the glue and the clamps and leave it all for another day.
Nearly there - I still need to level and smooth the table top, then sort out the finishing.
