• If you have bought, sold or gained information from our Classifieds, please donate to UK Workshop and give back.
    You can become a Supporting Member or just click here to donate.
Wanted Rear tote for No. 5 1/2
AESamuel
15 Jan 2015
Falmouth, Cornwall
Hi,
I'm restoring a Stanley style "Woden" branded no. 5 1/2 and the rear tote is unsalvageable. Does anyone have a rear tote that might fit? The base of the tote is 85mm long.
Thanks!
I have a spare tote off a Stanley plane, not sure how well it would fit, you can have it for P&P
I'll measure it tomorrow
Hi,
Thanks!
Is there enough meat on the old tote to cut it in half lengthwise on the bandsaw or the like. Then you can use one half as a template for cutting a fresh blank for shaping. You might be lucky and be able to mark out the holes for the screws from it too. I found it easier to mark out and drill these when the blank was still square and not cut to shape.
I did this for a Woden 4.5 and 5.5 a couple of years ago, still going strong now!
I would go with Pete's downloadable templates. I replace all my handles and knobs with my fancy-schmancy versions. If the original is useable I label it from which plane it came from and put it in a 'plane spares' drawer. No4 version:
If you could, that would be great!
I have tote blank that has been drilled for long screw ready for shaping (cut from lee valley template) if of interest
I believe Woden Stanley and Record tote handles are similar
That sounds good. If the spare tote from HOJ doesn't work out then I'll probably take you up on the offer, thanks!
